All things considered, almost any 3rd-party external NR software is
probably going to give you better results, as long as you use it correctly.
But I would be interested in seeing what the k-5 jpeg engine produces with NR on low, medium, high, vs. the same image taken through ACR NR or Topaz Denoise. Thom Hogan had
an aside in a recent article that I found intriguing, and made me wonder about the in-camera NR of the K-5:
From Thom Hogan re the D7000:
Quote: ...The bottom is the same file processed via ACR 6.3 Beta about as best as I could come up with using Adobe's sharpening and noise reduction controls plus a bit of other adjustment to make up for the deliberate slight underexpose I set in my tests (curiously, the camera wanted to set something close to my underexposure as its actual exposure, but that's a different story for a different day and is easily explained). Yes, there's some noise reduction smudging going on (the camera actually does slightly better in JPEGs than this).
