12-14-2010, 08:18 AM   #181
soppy's Avatar
Does anyone know if we can actually expect to see a firmware update after the first one we got? I just ordered my K-5, so I'm just curious if an update has been promised or if it is just speculation.
Note: I understand what would be in the firmware is definitely speculation, I'm just curious if an update in general was promised.
12-14-2010, 08:38 AM   #182
bobmaxja's Avatar
no promise , firmware come when Pentax feel is needed
12-14-2010, 09:48 AM   #183
ogl
ogl's Avatar
I've heard that new firmware would fix AF in low light with incandescent lamps.
12-14-2010, 01:49 PM   #184
Got another wish : permit MEMORY settings to be saved in the USER modes, so as to make them more dynamic...
This way you have even more control on what you want in your USER mode!
And to paraphrase myself again : put the damn movie mode on the Fx button, or on the Dof preview switch, with same controls as in the current Stills mode.
M mode + Movie button = full control.
Av mode + movie button = fixed aperture.
P mode + movie button = automatic.
Cannot be easier.
Those interested with manual movie controls will use this (in a USER mode, maybe?), the rest will just use the camera like now.
12-14-2010, 02:29 PM   #185
Option to activate shutter on grip only when body is rotated 90 degree CW or CCW. Person with big hands could accidentally activate shutter on grip when holding camera horizontally.
12-14-2010, 03:16 PM   #186
I agree that it is asking for trouble leaving both shutter releases turned on since it is easy to activate the vertical release if not careful. Many mysterious camera issues happened because I had the vertical release turned on If I am using the vertical, I turn it on and then turn it off when not using it. But I can see if somebody is in the thick of things with many rapid orientation changes, then they would both likely be on. Somehow, having an orientation-aware switch would seem to be potentially finicky, though.
12-14-2010, 03:43 PM   #187
alexeyga's Avatar
Would be nice to see either:
1)an additional AutoISO setting that allows to define the minimum shutter speed.
2)an additional custom setting that would change the Shutter Speed value in TAv mode into the "minimum allowable shutter speed" value...
Sport/bird shooters would understand....
12-14-2010, 03:44 PM   #188
soppy's Avatar
QuoteOriginally posted by alexeyga Quote
Anyone that does sports would like this as well I'd assume
12-14-2010, 05:33 PM   #189
Not sure I understand, Alexey. TAv implies that you are in control of the shutter speed.
12-14-2010, 06:27 PM   #190
QuoteOriginally posted by Arpe Quote
Okay, here's one I thought of today - how about a built-in dof calculator? Not sure how it would work, but with that screen on the back there's plenty of real estate. Maybe set the aperture, camera knows focal length - calculate dof and show it plus hyperfocal distance. Would save carrying around charts or your own separate calculator.
I really like this idea - should be simple enough yes?
Plus, none of the other makes do it, another first for Pentax! Way more useful than those "filters".
Yes, yes, yes. One of the biggest losses with digital lenses is a DOF scale. With the extended snout holding the built-in flash, it's also tough to see the DOF scale on film era lenses.
12-14-2010, 06:29 PM - 1 Like   #191
I would also like the K-5 to capture enough solar energy to reduce world-wide fossil fuel use by 50%.
12-14-2010, 07:35 PM   #192
soppy's Avatar
A hyper focal length calculator would be nuts if they could put it on there, but I think that falls under this category:
QuoteOriginally posted by civiletti Quote
12-14-2010, 09:04 PM   #193
Having manual video controls would seriously do it for me.
12-14-2010, 09:35 PM   #194
alexeyga's Avatar
QuoteOriginally posted by jbinpg Quote
If I wanted to be in full control of the shutter speed, i'd have used the M mode... howerver... let's say I'm shooting football in broad day light... minimum shooter speed to freeze the action is 1/500th... so I'd love to set iso to AUTO, shooter speed to minimum of 1/500th and only have Aperture to worry about...
What happens very often on a sunny day, even at f/11 at minimum iso, 1/500th is too slow... so pure TAv isn't good enough... For sports and birding it is essential to be able to define the lower shutter speed limit, but with no restriction of the high end... 1/8000th is still ok if iso is at minimum and i'm using the desired aperture value...
12-14-2010, 09:52 PM   #195
Yes, that would need a redesign of TAv. I just set the speed to the minimum I need in TAv and let the ISO go where it may.
2x, button, camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, lenses, mode, option, pentax k-5, user
Pentax K7 1.11 Firmware suggestions LaurenOE Pentax DSLR Discussion 26 06-21-2011 07:08 AM
People Need suggestions Atindra Post Your Photos! 1 11-03-2009 12:05 PM
Suggestions...PLEASE! stafford588 Pentax SLR Lens Discussion 10 01-02-2008 09:38 AM
Cr please and suggestions mingdie Post Your Photos! 9 09-15-2007 08:40 PM
Need some suggestions... Teko Pentax SLR Lens Discussion 18 01-21-2007 09:22 PM
All times are GMT -7. The time now is 01:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
