Originally posted by macTak Falk, I take it that the sensor (for both cameras) had that full well capacty allowing for a true lower ISO, but for whatever reason, Nikon decided not to go that low (unlike Pentax). That's what I meant by adding the option.
I know what you meant. Taken two sensors with the same full well capacity, the same quantum efficiency and the same analog gain setting (e.g., the same sensor actually).
Then both sensors have the same true base iso value, assuming the same microlens fill factor and bayer filter transparencies (which seems to be the case from the other curves).
Now, to go
below this true base iso value doesn't increase the DR anymore. It just stays constant (with a risk of overexposure). Even if such a thing as negative gain existed, if the well is full it is full. And Dxo measures ISO by observing pixel saturation. At negative gain, the pixel will never saturate and the so-called output dynamic range is damaged. That's not the case here. DxO observes 100% luminosity at K-5 vendor ISO 80.
The point is that your statement implies that Nikon wouldn't use the sensor at base ISO at all. But always with a gain of 91/70=83/70 or +19%.
That's a different statement from just cheating on iso and adding an option. E.g., Pentax could call their extended ISO "50". 50 isn't unheard of for a real value of 70. But it wouldn't change the result.
So, why shouldn't Nikon use the sensor at base gain already at ISO 100, or add an extended ISO 50 step? Not fully exploiting the sensor just doesn't make sense.
The only other idea I could come up with is that the Sony sensor documentation mentions some strange setting lowering the chip's quantum efficiency, e.g., by lowering the photon-electron conversion rate, maybe by applying some reduced voltage somewhere. That would be a strange thing possibly explaining why it is an extended setting for Pentax. But I don't believe this. Just enumerating the possibilities.
Also possible is that the sensor documentation lists gain factors which Pentax choose to underrun after finding out that there is some headroom, i.e., the lowest listed gain isn't the lowest preventing clipping the output DR.
This is a document of Sony's 12MP Exmor chip which may be used in the K-x:
http://www.sony.net/Products/SC-HP/cx_news/vol50/pdf/imx021.pdf
It talks about a programmable 24dB gain amplifier. 24dB are 4 stops spanning a region e.g., from ISO 160 to ISO 2500. Any gain above must be done in software, any "gain" below by overexposure. As the gain amplifier must be on chip, Nikon and Pentax have to use the same one. I can't see why Nikon wouldn't use the 0dB setting...
However, I've not found a corresponding document for the sensor in the K-5.
