11-09-2010, 07:46 PM   #1
new k-5 and issue with 360fgz
finally got the k-5 (thanks newegg) and mounted the da40 and my 360fgz flash. taking indoor pcitures i noticed that most shots were over-exposed when using the 360 fgz set at ttl and bouncing light of the ceiling. with my k20d, using same flash and ttl settings, pictures were about 1/3 stop under-exposed (my k20d shot with or without flash, indoors or outdoors a little under-exposed).
switching the 360fgz to auto mode seems to fix the problem. i would have thought that ttl would have given more accurate metering and flash intensity. would like to solicit any thoughts or see if any k-5 owners have had the same issue.
thanks.
11-09-2010, 07:54 PM   #2
Senior Moderator
Parallax's Avatar
My experience with TTL and P-TTL with external flash is that the technology is in serious need of refinement. I use mine in Auto mode so I know what to expect.
The strange thing is that the built in flash gives very consistent and predictable results, but my 360 is all over the place for exposure.
11-09-2010, 08:03 PM   #3
A couple others, including me, have observed this same behavior with the K-5 and P-TTL bounce flash. Direct flash seems to work ok. See these threads for more discussion about this:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/119630-my-2-days-old-k5-faulty.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/119808-k-5-flash.html
This is now clearly more than an isolated incident with several people independently reporting the same problem. I'm personally waiting for the upcoming firmware update to see if it fixes the bug.
11-09-2010, 08:51 PM   #4
All would be fixed if the newer DSLRs implemented TTL technology. I still wish Pentax would go back to including that.
11-09-2010, 09:04 PM   #5
jpzk's Avatar
There seems to be an escalation of the K5 flash "issue".
This being the third thread (at least) on the subject.
Sure comes at a handy time when I am trying to learn flash photography and hoping the K5 would be the ideal camera for that. Luckily enough, I still have my K7 which does not have such issue.
Does anyone have any answer from Pentax yet?
If this is a firmware fix, well, please Pentax do it soon.
If this is harware related .... I am postponing my acquisition of the K5 until it is fixed. It was ordered last week but I am not obliged to buy it.
Why not start a specific thread and send all of the "complaints" to Pentax? ... just a suggestion.
JP
11-09-2010, 09:21 PM   #6
What mode are you shooting in? I have only played with the flash a little on the K-5, but it seems like it tends to overexpose on TAv mode (picked a really high ISO based on ambient light). In Manual, with a more normal ISO, it exposed fine. Note, however, that this was with direct flash through a diffuser and small softbox.
11-09-2010, 09:36 PM   #7
jpzk's Avatar
QuoteOriginally posted by blockamon Quote
I tried Av, which is the mode I prefer for controlling the aperture, Bokeh, OOF areas, etc ...
Quite a bit of overexposure at wide open and getting increasingly darker as I stop down with the same settings.
I suppose I have to adjust accordingly?
JP
OOps! I thought this was meant for me ... sorry to the OP.
11-09-2010, 10:41 PM   #8
I'm nervously awaiting the firmware update for this as well.....
It shouldn't be a hardware issue - there's no reason they can't get P-TTL as good as the K-7, which had accurate flash, both direct and bounced.
11-10-2010, 05:43 AM   #9
I have no issues at all with K-5 & Metz 48 in P-TTL, bouncing off the walls and ceiling.
11-10-2010, 06:01 AM   #10
Has anyone contacted Pentax regarding this issue.Will others with K5 and the 360 run some test.These bugs are normal in early runs of new models,and bet will be fixed with other yet to be discovered bugs.
11-10-2010, 06:27 AM   #11
Naim Khan's Avatar
Hi,
I have just posted an update in this thread:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/119808-k-5-flash-2.html
Cheers
11-10-2010, 06:41 AM   #12
QuoteOriginally posted by simico Quote
Same here with a Sigma 530 Super...
11-10-2010, 06:52 AM   #13
apologies for not finding the other flash issues. i also shoot in aperture control primarily. hoping for a fix in firmware no.2
360fgz, camera, dslr, flash, issue, k-5, k-5 ii, k-5 iis, k20d, k5, pentax k-5, ttl, under-exposed
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Issue with my 360FGZ.... heeeeelp !!!! Wildfire_ja Pentax Camera and Field Accessories 2 05-06-2009 02:37 PM
A printer issue, or a processing issue... FHPhotographer Digital Processing, Software, and Printing 0 10-03-2008 12:13 PM
360FGZ Adapter/Trigger Issue Sauvage Pentax Camera and Field Accessories 1 08-06-2007 01:46 PM
All times are GMT -7. The time now is 05:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
