Glad this helped. The image contains full EXIF, but here is the exiftool output for you:
---- ExifTool ----
ExifTool Version Number : 8.39
---- System ----
File Name : IMGP0281.jpg
Directory : /Users/phil/Desktop
File Size : 6.4 MB
File Modification Date/Time : 2010:11:11 09:40:53-05:00
File Permissions : rw-r--r--
---- File ----
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Current IPTC Digest : 7aa646bd294f919a0fc03e0c466e7ba9
Image Width : 2354
Image Height : 3553
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:4:4 (1 1)
---- IFD0 ----
Make : PENTAX
Camera Model Name : PENTAX K-5
X Resolution : 240
Y Resolution : 240
Resolution Unit : inches
Software : PENTAX Digital Camera Utility Ver.4.31
Modify Date : 2010:11:10 18:39:04
---- ExifIFD ----
Exposure Time : 1/800
F Number : 2.8
Exposure Program : Aperture-priority AE
ISO : 6400
Exif Version : 0221
Date/Time Original : 2010:11:09 17:44:21
Create Date : 2010:11:09 17:44:21
Shutter Speed Value : 1/800
Aperture Value : 2.8
Exposure Compensation : 0
Metering Mode : Multi-segment
Flash : Off, Did not fire
Focal Length : 80.0 mm
Sensing Method : One-chip color area
Custom Rendered : Normal
Exposure Mode : Auto
White Balance : Manual
Focal Length In 35mm Format : 120 mm
Scene Capture Type : Standard
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Subject Distance Range : Distant
---- Pentax ----
Pentax Version : 7.0.0.0
Pentax Model Type : 0
Preview Image Size : 640x480
Preview Image Length : 0
Preview Image Start : 35150
Pentax Model ID : K-5
Date : 2010:11:09
Time : 17:44:21
Quality : RAW
Flash Mode : Off, Did not fire; Internal
Focus Mode : AF-S
AF Point Selected : Fixed Center
F Number : 2.8
ISO : 6400
Auto Bracketing : 0 EV, No Extended Bracket
Saturation : Normal
Contrast : Normal
Sharpness : Normal
DSP Firmware Version : 1.00.00.01
CPU Firmware Version : 1.00.00.01
Effective LV : 6.5
Picture Mode : Aperture Priority; 1/3 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Color Space : sRGB
Image Area Offset : 22 10
Raw Image Size : 4928x3264
Preview Image Borders : 28 28 0 0
Lens Type : smc PENTAX-DA* 50-135mm F2.8 ED [IF] SDM
Camera Temperature : 30 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0
Image Tone : Natural
SR Result : Not stabilized
Shake Reduction : On (7)
SR Half Press Time : 0.43 s
SR Focal Length : 80 mm
Shutter Count : 273
Faces Detected : 0
Face Position : 0 0
Hue : Normal
Tungsten AWB : Strong Correction
Dynamic Range Expansion : Off
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : Toronto
Destination City : Toronto
High/Low Key Adj : 0
Contrast Highlight : 0
Contrast Shadow : 0
Contrast Highlight/Shadow Adj : Off
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Medium; Active (Medium)
AF Adjustment : 0
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : Off; 0 faces detected
Face Detect Frame Size : 0 0
Shadow Compensation : Off
Distortion Correction : Off
Chromatic Aberration Correction : Off
Bleach Bypass Toning : Off
Black Point : 0 0 0 0
White Point : 13248 8192 8192 16256
Picture Mode 2 : Aperture Priority
Program Line : Normal
EV Steps : 1/3 EV steps
E-Dial In Program : Tv or Av
Aperture Ring Use : Prohibited
Flash Options : Normal
Metering Mode 2 : Multi-segment
AF Point Mode : Fixed Center
Focus Mode 2 : AF-S
AF Point Selected 2 : Center
ISO Floor : 6400
Drive Mode 2 : Single-frame
Exposure Bracket Step Size : 0.3
Bracket Shot Number : n/a
White Balance Set : Auto
Multiple Exposure Set : Off
AE Exposure Time : 1/683
AE Aperture : 2.8
AE ISO : 6400
AE Xv : 0
AEB Xv : 0
AE Min Exposure Time : 1/7723
AE Program Mode : Av, B or X
AE Max Aperture : 0.1
AE Max Aperture 2 : 2.8
AE Min Aperture : 3
AE Metering Mode : [2], [3], [7]
Flash Exposure Comp Set : +8.0
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Nominal Max Aperture : 2.8
Nominal Min Aperture : 23
Max Aperture : 1.0
Flash Status : Off (1)
Internal Flash Mode : n/a - Off-Auto-Aperture
External Flash Mode : Not Connected
Internal Flash Strength : 63
TTL DA A Up : 0
TTL DA A Down : 0
TTL DA B Up : 0
TTL DA B Down : 0
External Flash Guide Number : n/a
External Flash Exposure Comp : n/a
External Flash Bounce : n/a
AE Metering Segments : 4.2 4.1 5.1 5.1 5.9 6.1 5.6 6.4 6.6 6.4 6.4 4.4 4.2 5.2 5.2 6.0 6.1 5.8 6.4 6.6 6.5 6.6 4.4 4.5 5.1 5.0 5.9 5.9 5.9 6.2 6.5 6.4 6.6 4.4 4.9 4.9 4.9 5.9 6.0 6.8 4.9 5.5 6.1 6.4 4.5 4.8 5.0 4.0 5.5 5.9 6.2 5.4 5.8 5.9 6.4 4.4 4.5 5.2 5.5 5.9 5.9 5.9 6.0 6.2 6.1 6.2 4.2 4.9 5.8 5.5 6.1 6.5 6.6 6.8 6.4 5.8 6.1
Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Slave Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Manufacture Date : 2010:10:12
Production Code : 2.1
Internal Serial Number : 13203
Power Source : Body Battery
Body Battery State : Full
Body Battery A/D No Load : 2
Body Battery A/D Load : 234
Grip Battery A/D No Load : 2
Grip Battery A/D Load : 202
AF Predictor : -4
AF Defocus : 2
AF Integration Time : 30 ms
AF Points In Focus : Center (vertical)
WB Shift AB : 0
WB Shift MG : 0
EV Steps : 1/3 EV Steps
Sensitivity Steps : 1 EV Steps
Camera Orientation : Rotate 90 CW
Serial Number : 3836389
Level Orientation : Rotate 90 CW
Roll Angle : 0
Pitch Angle : -9
---- IFD1 ----
Compression : JPEG (old-style)
X Resolution : 72
Y Resolution : 72
Thumbnail Offset : 35244
Thumbnail Length : 17129
---- Photoshop ----
X Resolution : 240
Displayed Units X : inches
Y Resolution : 240
Displayed Units Y : inches
Photoshop Thumbnail : (Binary data 17129 bytes, use -b option to extract)
---- IPTC ----
Application Record Version : 2
Keywords : new keyword
---- ICC-header ----
Profile CMM Type : Lino
Profile Version : 2.1.0
Profile Class : Display Device Profile
Color Space Data : RGB
Profile Connection Space : XYZ
Profile Date Time : 1998:02:09 06:49:00
Profile File Signature : acsp
Primary Platform : Microsoft Corporation
CMM Flags : Not Embedded, Independent
Device Manufacturer : IEC
Device Model : sRGB
Device Attributes : Reflective, Glossy, Positive, Color
Rendering Intent : Perceptual
Connection Space Illuminant : 0.9642 1 0.82491
Profile Creator : HP
Profile ID : 0
---- ICC_Profile ----
Profile Copyright : Copyright (c) 1998 Hewlett-Packard Company
Profile Description : sRGB IEC61966-2.1
Media White Point : 0.95045 1 1.08905
Media Black Point : 0 0 0
Red Matrix Column : 0.43607 0.22249 0.01392
Green Matrix Column : 0.38515 0.71687 0.09708
Blue Matrix Column : 0.14307 0.06061 0.7141
Device Mfg Desc : IEC
IEC - International Electrotechnical Commission > INTERNATIONAL STANDARDS AND CONFORMITY ASSESSMENT
Device Model Desc : IEC 61966-2.1 Default RGB colour space - sRGB
Viewing Cond Desc : Reference Viewing Condition in IEC61966-2.1
Luminance : 76.03647 80 87.12462
Technology : Cathode Ray Tube Display
Red Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
Green Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
Blue Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
---- ICC-view ----
Viewing Cond Illuminant : 19.6445 20.3718 16.8089
Viewing Cond Surround : 3.92889 4.07439 3.36179
Viewing Cond Illuminant Type : D50
---- ICC-meas ----
Measurement Observer : CIE 1931
Measurement Backing : 0 0 0
Measurement Geometry : Unknown (0)
Measurement Flare : 0.999%
Measurement Illuminant : D65
---- Adobe ----
DCT Encode Version : 100
APP14 Flags 0 : [14]
APP14 Flags 1 : (none)
Color Transform : YCbCr
---- Composite ----
Aperture : 2.8
Base Name : IMGP0281
File Extension : jpg
File Type Description : Joint Photographic Experts Group
Image Size : 2354x3553
Lens ID : smc PENTAX-DA* 50-135mm F2.8 ED [IF] SDM
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/800
Thumbnail Image : (Binary data 17129 bytes, use -b option to extract)
Circle Of Confusion : 0.016 mm
Field Of View : 17.1 deg
Focal Length : 80.0 mm (35 mm equivalent: 120.0 mm)
Hyperfocal Distance : 138.68 m
Light Value : 6.6
Hmmm. Looks like I probably didn't rotate this particular image in post-processing after all. The RollAngle was exactly 0 degrees! (I'm impressed, because that is hard to do -- the electronic level measures with a 0.5 degree accuracy.)
- Phil
