Originally posted by kari Correct me if I'm wrong, but I'm pretty sure that the plate does not lock into place as the shutter opens as that would defeat the purpose of SR completely.
Well with SR off it does, with SR on the onboard computer will continuously calculate where the sensor plate should be (to counteract movement) and then move the plate to that position. Thus as long as the shutter is open, the sensorplate will not be loose, it will be in a controlled position. (Unless you shake too much, then the SR system will consider the shoot a loss and drop the sensor and it will again be loose.)
