11-13-2010, 10:13 AM   #1
m8o's Avatar
Can long exposure times harm the sensor in the K-5?
[mods, please move to general DSLR or other if more appropriate]
The K-5 has proven to be able to take hour+ long exposures w/negligible noise. My question however is, can doing so actually damage the sensor, increasing the noise it produces over time much faster than the normal degeneration of the sensor, if not causing it to fail much sooner than otherwise?
I ask because most if not all the CMOS sensors I've read about used in special-purpose astrophotography setups (which aren't that many) are usually water cooled. And I'm not entirely sure if that is/was done to a) keep it cool and reduce the level of spurious noise produced, or b) to keep it from self-destructing ... I'd always thought, both, but maybe I'm wrong.
Anyone with some [preferably 1st-hand] knowledge in this realm know? I would be more likely to take 120 30s exposures in RAW and stack them than a single 1 hour exposure if there is risk to the sensor w/the latter if stock and not liquid cooled.
11-13-2010, 10:46 AM   #2
Short answer, No. Don't worry the heat build up would just add more electronic noise, this is why astro cameras use Peltier coolers to bring the aforementioned noise (shot noise) down. Typically to kill silicon junction devices you need temperatures around 150 C!!!! Not going to happen by using your camera unless it's inside an oven.
11-13-2010, 10:46 AM   #3
I use my old K100D for long Bulb Mode exposures, mainly because I can turn off DFS completely, unlike the K-7.
But it being an relatively elderly, backup body is a factor , so its obvious I have a concern like yours - I don't use my latest camera
My K100D does have an increasing number of hot pixels, not sure if its directly related to long exposures, but the camera and sensor are still going strong. It may die on me tomorrow , who knows ? , but its still working fine right now.
The new K-5 looks like an awesome tool for long exposures, but I do have a bit of concern using my latest and best camera for this strenous (?) task.
11-13-2010, 05:53 PM   #4
78 Minutes.
Taken the following day...
Same lens, same camera, same card so, I guess no damage..
11-13-2010, 06:30 PM   #5
m8o
m8o's Avatar
QuoteOriginally posted by JeffJS Quote
Well, I never thought there would be instant damage; was wondering if over time the sensor would degrade and/or possibly fail sooner. But regardless, looks like no in any case.
11-13-2010, 07:07 PM   #6
QuoteOriginally posted by m8o Quote
Well, since the oldest K5 in use is probably no more than a month old, Who would Know?
11-13-2010, 07:26 PM   #7
m8o
m8o's Avatar
Meant it as a "is the CMOS, used in the K-5, susceptible" query. But yes, certainly, who's to know if its particular CMOS [a different acronym actually] would be equally susceptible if any are... which anyway, seems not.
11-13-2010, 08:01 PM   #8
I guess I'm feeling a little snarky tonight.. Sorry for the short sounding response... Fact is, I don't know if it's susceptible. Pentax has put heat protection into the circuits so that if the sensor overheats during Live View, the shutter will close (same with video clips). One would like to think the sensor can take quite a bit in terms of long exposures. Then again, one would like to think a lot of things. Most of which may not be true
11-13-2010, 08:05 PM   #9
I know my GX10 has developed quite bad sensor blooms from doing long exposures, and every time I do one it gets a little worse. It's to the point that even if I do a bunch of shots in a row at ISO 1600 it can shot up a little. But that is a CCD not a CMOS so there may be a difference.
11-13-2010, 09:30 PM   #10
This is exactly why I will be buying an extended warranty, most likely from squaretrade.com unless someone knows a cheaper one that is good.
camera, cooled, dslr, exposure, exposures, hour, k-5, k-5 ii, k-5 iis, k5, noise, pentax k-5, sensor
Black & White Long exposure with the LX nickthetasmaniac Post Your Photos! 5 09-09-2010 09:45 AM
How long will fresh batteries last in long exposure? tnis0612 Troubleshooting and Beginner Help 6 05-18-2010 09:11 AM
What possible harm could I have done .... daacon General Talk 58 08-07-2009 12:08 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
Time Exposure - Bulb setting - Read write times Vatis Pentax DSLR Discussion 7 09-05-2007 07:38 AM
All times are GMT -7. The time now is 03:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
