Hi,
Yes the lighting is fluorescent, thats what I meant by tube (i should be more clear)
Now before you all shout noob
I do mostly indoor stuff and not come across this problem before.
So a quick test ( no means through) the k5 will band/cast ( just for a better word) with a shutter speed of hundeds (and easy to) - but try as I might the k20d would be a lot higher .
After reading up
I totally understand the "problem" (and I'm sure I've come across it before but forgot).
But anyone get really pronounced blue casts in fluorescent ( monitors etc ), I get really odd pronounced blue specular hi lights on objects if a fluorescent light souce casting even a bit of light on them ( I've seen this in other k5 images tp).
I'll post some images later ( all prepaired for user error to
Cheers
