11-17-2010, 09:19 PM   #16
QuoteOriginally posted by Jeff Charles Quote
Thanks. How about being able to review while the buffer is clearing?
Sorry, I was probably editing my last post with the answer to that while you were writing.
The answer is no, you can't go into playback mode until the buffer is cleared. However, the instant review of the last photo you took will still pop up after a few seconds.
Did the firmware update make it possible to switch between 14 bit and 12?
I can't find any toggle for 14/12 bit, so I assume no.
11-17-2010, 09:30 PM   #17
Thanks
QuoteOriginally posted by Cannikin Quote
Yes, if you hit the playback button, it will display the hourglass symbol until all photos are done processing.
Wow. That's pretty bad, and it should not be necessary. My D90 starts displaying images at about 1 second intervals immediately after the burst ends.
Jeff
11-17-2010, 09:40 PM   #18
Wheatfield's Avatar
Jeff
Give it a rest, life isn't about how fast you can go from photographer to apeman.
11-17-2010, 09:49 PM   #19
Thanks
Thanks. It's not a deal breaker, but it is a little bit disappointing.
I was thinking that they might use that approach to increase the number of shots per burst, but it looks like I was wrong. I'd like to see a 12 bit mode to reduce file sizes, especially at high ISOs when, as I understand it, the extra 2 bits don't help.
Jeff
11-17-2010, 10:05 PM   #20
Nothing wrong with chimping :)
Sometimes I like to do a quick review to see if I got the shot. I have seen many professionals do the same. The LCD is there for that purpose. Thirty seconds can be a long time in some situations.
Jeff
11-17-2010, 10:55 PM   #21
Wheatfield's Avatar
Jeff
If you've missed the shot, you've missed the shot. How is playing apeman going to get it back?
The LCD is there for many purposes, only one of which is to review pictures.
I've seen many professionals miss shots because they were looking at the screen rather than paying attention to their job.
11-17-2010, 10:59 PM   #22
nulla's Avatar
Was the flash issue addressed at all or any mention of it?
I am at work and cannot download at the moment
11-18-2010, 07:03 AM   #23
Trig's Avatar
Awesome! Can't wait to update the firmware when I get home.
11-18-2010, 08:32 AM   #24
macTak's Avatar
Can someone test the continuous LOW now. I'd like to know how many RAW shots you can get with that now (also if it's still 1.6fps).
11-18-2010, 09:17 AM   #25
does the issue with different exposure when using liveview and viewfinder is addressed? can anyone check, whether, it still exposes differently when using liveview?
11-18-2010, 09:48 AM   #26
QuoteOriginally posted by macTak Quote
It's still 1.6,which I really don't get. It's so uselessly slow. The only thin I could imiagine using it for is locking the shutter down for doing time lapses fast than 1 second intervals. I guess they're thought process might have been if you have a K-7 and K-5 then you have 1.6, 3, 5.2 & 7 fps available to have different rates for different things. But it would sure make a lot more sense for the K-7 to 1.6 & 5.2, and the K-5 to be 3 & 7. And, even bumping it up to 2fps would have been something more useful.
11-18-2010, 03:27 PM   #27
QuoteOriginally posted by JamieP Quote
Just updated as well. I'm not a big fan of the way the orange light continues to blink even after the screen says complete. To me the blinking light makes it seem that some process is still running. I let it go for a few extra minutes to make sure it was done. The blinking never stopped, so I turned it off. Everything was fine.
I have to admit, probably to the dismay of the current readers, that my rear end puckers a little more when I do these firmware updates. I for one, Really appreciate the double confirmation of both "Completed" AND the blinking light when it's finished.
11-18-2010, 04:48 PM   #28
amoringello's Avatar
Just upgraded and shot 21 frames high speed RAW+JPEG @ ISO800, 19 frames @ ISO 51200.
I think I let out a giggle like a little girl for just a second... OK, maybe two seconds. :-)
Lo speed is pretty darned slow. I did not max out the frames in a row. Didn't see the point.
I never tried Lo Speed or even read up on what speed it was supposed to be, so I was a bit surprised at how slow that was. I would find 3-4 per second a lot more useful, (if I ever found a lesser that top speed useful). I wonder what reasoning they had for that speed?
11-18-2010, 04:59 PM   #29
Arpe's Avatar
It's not, but it may mean one can try again to get it before it's too late.
---------- Post added 19th Nov 2010 at 01:00 PM ----------
QuoteOriginally posted by amoringello Quote
So they can say "until card is full", which sounds impressive.
11-18-2010, 05:06 PM   #30
YAYAYA frame buffer sorta fixed!
camera, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, k5 firmware, pentax k-5
K-x firmware update justonecat Troubleshooting and Beginner Help 15 03-23-2011 08:59 PM
Help with k-x firmware update kiwislice Pentax DSLR Discussion 7 02-25-2010 12:57 PM
Need Help to Update Firmware JamesD Pentax DSLR Discussion 22 10-20-2007 04:34 PM
Firmware Update benjikan Pentax DSLR Discussion 7 03-06-2007 02:22 PM
Firmware update vievetrick Pentax News and Rumors 0 09-07-2006 12:20 PM
All times are GMT -7. The time now is 01:25 PM. | See also: NikonForums.com, part of our network of photo forums!
