11-18-2010, 07:43 AM   #1
aaronius's Avatar
What are the difference between the 3 sharpness settings in K5?
Hi guys, I just got the K5 and realise that it has 3 different sharpness settings:
1) Sharpness
2) Fine Sharpness
3) Extra Fine Sharpness
What are the differences between the 3 different sharpness settings? Is Extra Fine Sharpness the best in sharpness but introduce more noise and artifacts? And sharpness is just default sharpness and not as sharp as the other 2 options?
What settings you guys use?
11-18-2010, 08:45 AM   #2
SpecialK's Avatar
I'm guessing your own answers are probably pretty accurate, though if you shoot RAW those settings, and many others, have no real use.
11-18-2010, 08:49 AM   #3
imtheguy's Avatar
According to the manual, p222, Fine and Extra Sharpness use thinner image outlines than normal sharpness.
11-18-2010, 09:41 AM - 1 Like   #4
inferno10's Avatar
In their review of the K-5, NeoCamera posted a little interactive section showing off the differences in the 3 sharpness settings, through the entire range of each mode. This should clearly show you the difference:
Pentax K-5 Sharpness Settings | Neocamera
- Jason
11-18-2010, 09:50 AM   #5
QuoteOriginally posted by inferno10 Quote
- Jason
I was looking at that review last night, and they did a great job showing the differences between the different sharpness settings. I must say, the Extra Fine sharpness does look sharp, but I wonder if it would introduce too much noise in everyday photos. With my previous K200D, when doing my own testing, I definitely preferred the regular sharpness to the fine sharpness. Now, I'll have to do some testing with my K-5.
11-18-2010, 09:56 AM   #6
chalion's Avatar
This looks like it has a finer degree of sharpness the the high range compared to my K20D & K200D, considering the differences in megapixel range of these cameras. It will look to be a boon for people taking macro pictures.
11-18-2010, 10:19 AM   #7
imtheguy's Avatar
- Jason
Your answer nails it. Thanks.
+1 rep
camera, dslr, guys, k-5, k-5 ii, k-5 iis, k5, pentax k-5, settings, sharpness, sharpness settings
HDR: Does the exposure settings in the K7 make much of a difference compared to K20D? Lulerfly Pentax DSLR Discussion 1 11-07-2010 09:25 AM
K20D Sharpness Settings? azcavalier Pentax DSLR Discussion 2 11-11-2009 11:28 AM
JPEG sharpness and the K-7. What settings produce the best results? r0ckstarr Troubleshooting and Beginner Help 4 10-18-2009 09:56 AM
difference between k-7 settings Nass Pentax DSLR Discussion 3 10-14-2009 05:39 AM
Do you customize the Sharpness, Contrast and Saturation settings on your DSLR? lastdodobird Pentax DSLR Discussion 12 01-30-2008 07:41 AM
All times are GMT -7. The time now is 10:31 AM. | See also: NikonForums.com, part of our network of photo forums!
