11-18-2010, 11:52 PM   #1
m8o's Avatar
Does K-5's AF Fine Tune work on your Sigma HSM lens?
... this is in regards to my K-5 + 70-200mm f/2.8 HSM II ....
After a short honeymoon I soon came to realize that the critical focus region is noticeably in-front of the focus point. Using various subjects with surface detail at a 45-ish deg angle to me at distances near as well as well over MFD, I've went from -10 <-> +10 for the adjust all and adjust one settings taking many shots along the way. And at no time has any of it altered the in-focus region in relation to my focus point. ??? Am I the only one?
11-19-2010, 12:37 AM   #2
AF Fine Tune does work with the Sigma 17-70mm (screw drive), only it doesn't recognise it as a specific lens model, just "Sigma Lens". Pentax lens ID doesn't seem to work well with Sigma.
I don't have a Sigma HSM lens, so can't I comment on it
Have you tried adjusting AF with the lens on another Pentax with AF Fine Tune e.g. K-7 or K20D ?
11-19-2010, 09:53 AM   #3
m8o
m8o's Avatar
I don't have the K-7 or K20D. Maybe I'll try and see if there's one @ a retailer I can try it on.
However you bring-up and interesting point. I was wondering if I should be seeing something specific to a lens. I see now, yes, I should. I don't even see "Sigma Lens" anywhere in the AF Fine Tune section.
11-19-2010, 11:12 AM   #4
kent's Avatar
keep in mind, that sigma 70-200mm II has a focus shifting at close distance, which means, that you never know where is true focus .
11-19-2010, 12:07 PM   #5
m8o
m8o's Avatar
QuoteOriginally posted by kent Quote
I see the same behavior with subjects 3 meters away, and an inability to adjust is the same. I am of like mind wondering if I know for sure what is getting focused on. Though I'm selecting a specific focus point, or using center-only, I'm going to switch to 5 point focusing later and re-try the subjects I was using last night.
11-19-2010, 02:35 PM   #6
I've found more or less an identical problem with a Sigma 17-70 HSM that was AF perfect on my K7 (see thread K5 and AF accuracy with Sigma 17-70mm HSM lens)
Adjusted to -10 my lens misses focus by less than at 0, but is still focusing at a point closer to what it should.
I've tried the Sigma lens on two K5 bodies and it performed identically; Pentax-branded lenses were perfect on both bodies.
Pentax may have made software changes that cause problems with Sigma HSM lenses. Or there's a less conspiratorial explanation. Whatever the reason, I'd love to find a solution.
11-19-2010, 07:42 PM   #7
m8o
m8o's Avatar
Thanx for that. BTW, do you see lens as "Sigma Lens" in the AF Fine Adjustment section, or nothing at all?
11-19-2010, 09:00 PM   #8
My Sigma 50mm f/1.4 shows up as a Sigma 70-200 on the EXIF data. I am going to buy the Sigma 85mm so if I find one of them needs AF adjust I will probably sell the Sigma 50 and get the DA* 55mm. I'm not sure if different Sigma lenses register different or not.
11-20-2010, 11:13 AM   #9
QuoteOriginally posted by m8o Quote
I see nothing at all in the AF Fine Adjustment section beyond the adjustment bar and the option to apply the adjustment to one lens or all lenses.
11-20-2010, 11:24 AM   #10
philbaum's Avatar
QuoteOriginally posted by amvic Quote
Just for the heck of it, why don't you try the all lenses option and see if that makes a difference to the Sigma's focus adjustment??? If that works, at the very least, you could make a change when you're going to be using that lens for awhile.
Let us know if you would. I've not had a problem making adjustments on my K20, but have never tried that with a Sigma.
11-20-2010, 11:33 AM   #11
blende8's Avatar
I have only one Sigma and this is the Sigma 20/1.8.
It needed a focus correction on the K20 and when I got the K5 yesterday I found that exactly the same value is fitting on the K5.
So, it definitely works and it is consistent.
EDIT:
Oops, I have two Sigma lenses.
I also have the Sigma 180/3.5 Macro.
This does not need a correction.
11-20-2010, 01:19 PM   #12
Hi blende8,
So every time when you switch between your sigmas, do you need to go into the menu to change the AF fine tune values?
11-20-2010, 01:24 PM   #13
RonHendriks1966's Avatar
QuoteOriginally posted by blende8 Quote
I had the same experience for the adjusting of lenses that they all ended up with the same correction setting as in my K-7.:ugh:
11-20-2010, 01:33 PM   #14
blende8's Avatar
QuoteOriginally posted by rudemood11 Quote
No.
The body recognizes the lens and sets the values accordingly.
I just checked again in the menu.
When I mount the Sigma 20, the correction -8 is set.
When I mount the Sigma 180, the value is zero.
11-20-2010, 01:48 PM   #15
QuoteOriginally posted by philbaum Quote
Tried it, neither all nor individual lens adjustment achieved sufficient correction to cure my Sigma 17-70 HSM's front focus problem.
adjust, af fine tune, camera, dslr, focus, hsm, k-5, k-5 ii, k-5 iis, k5, pentax k-5, region, sigma hsm
Sigma 17-50mm F2.8 EX DC OS HSM Lens Now Available openyourap Pentax News and Rumors 22 07-16-2010 04:55 PM
K-7 AF fine tune on zoom lenses? Jasvox Pentax DSLR Discussion 3 05-08-2010 06:57 AM
K20d settings on fine tune WB! Help? vitalsax Pentax DSLR Discussion 4 04-24-2009 01:37 PM
lens tune up?? cleaning etc dcmsox2004 Pentax SLR Lens Discussion 5 04-14-2009 03:56 AM
Sigma 18-250mm f/3.5-6.3 DC OS HSM IF Lens shiner Pentax SLR Lens Discussion 2 03-10-2009 05:54 AM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
