Originally posted by Class A Why don't you do it with the AF fine adjustment setting(s)?
If the correction values required exceed the range provided (-10 - +10?) then any software adjustment you may reach with the debug mode won't help either. BTW, a correction value of +10 would be used to compensate for back-focus. If you use +10 for a lens that does not need adjustment, it will front-focus.
If the camera really has an overall FF bias then you'll be better off to have the calibration done optically, i.e., by mechanically moving the AF module plate. On earlier Pentax models this could be done by adjusting three screws under the bottom plate of the camera. I don't know whether the K-5 is the same in this regard. However, in any case I wouldn't attempt that myself without the optical test bench and corresponding software required. It will be very easy to optimise for one AF point but mess up others.
Yeps, i'm at +10 for most of my lenses with the K-5.
Playing with the debug mode on the K-7 shows that the FF adjustments in it goes well beyond what the user settings will do. i ended up dialing in an overall +something into the debug mode and it put me into the right zone in the user settings where i could set fine AF correctly with all my lenses.
It's odd that most of my lenses are +10 and beyond for the K-5 whereas they're all over the place with the K-7.
--Still, there'll be some more wearing in of the SR parts on the K-5. That was so with the K-7 too; adjustments moved around some for like 7-8 months before settling down.
Definitely i shouldn't be disassembling the camera. i'm one of those guys who used to take everything apart and always wind up with a spring or 2 left over when i put it back together.
At least, not while the thing's under warranty.
i can see it now: i get the camera back together in one piece, and look, there's a lever still in the parts tray, and that looks like a piece of the shuttter curtain!
It's OK; i don't need it!!
