06-08-2012, 01:34 AM   #31
Hi,
Try this number; 00077430.505 to debug your K5
06-08-2012, 04:41 AM   #32
Not working here.
06-08-2012, 09:56 AM   #33
just use the pk_tether...its the easiest way to activate the debug mode
02-23-2014, 06:11 PM   #34
Hi, still nobody figured the magic number for %08.%03 file?
I know we can enable debug mode via pkteether but I would like to enable scripting. As I quickly inspected decrypted FW it still contains references for autorun file and script commans so it should be possible. The second number is 524 for K-30, I'm pretty sure. But the %08 number?
Or if someone know how to fix firmware checksum, then why not to replace the string %08.%03 by e.g. config.sys
02-23-2014, 06:21 PM   #35
QuoteOriginally posted by RayeR Quote
It's been found recently
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/250555-resurrect...ml#post2694117
02-23-2014, 07:50 PM   #36
Thanks, very interesting thread!
I must immediatelly tried it and debug menu, devel mode and scripting works!
06-03-2014, 11:59 AM   #37
To enable the debug mode I used PK Tether software. Its has been the easiest way for me
But the question is : How to correctly perform the "FocusCorr" to remember the adjustment for each lens on the Pentax K-5 ?
I performed the correction for my Pentax 50 1.4 ( +80um ). Then I tried to perform correction for Sigma 70-200 2.8 but the camera remembered the value +80um for previous mounted 50 1.4.
I reseted the value to 0um. Then again mounted 50 1.4 and I had to perform the correction again to +80um becase the camera did not remember the value +80um.
What did I wrong ?
I think that my previous K-10 remember the adjustment for each lens...
Please help me
What step by step ? Is there important the "AF Area test " and "AF Area Number" ?
Thanks, BlackM
06-03-2014, 02:17 PM   #38
QuoteOriginally posted by BlackM Quote
The K-5 does too. It by default will save individual settings for 20 lenses [Custom > AF Fine Adjustment > Apply One], if it can identify the specific lens mounted.
It may not remember the individual settings adjusted via debug mode, however. [+] 80 also seems way out of parameters. Are you testing right?
06-09-2014, 01:58 AM   #39
Serpiente's Avatar
Interesting! My K-5 is backfocussing since the last firmware update (before it was on +4 and sharp)! I put it on +10, but I think +11/+12 would have been better.
It is with the HD DA15 Ltd.
camera, debug, dslr, k-5, k-5 ii, k-5 iis, k5, menu, mode, pentax k-5
k-7 debug mode - how to enter Nass Pentax DSLR Discussion 17 01-17-2015 04:56 PM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
K10D Firmware 1.3 Debug Mode Unleashed! RiceHigh Pentax DSLR Discussion 148 10-01-2010 01:48 PM
How to access Debug Mode of Pentax K200 Thareen Pentax DSLR Discussion 28 04-08-2010 01:39 PM
Debug mode on K-x. ilya80 Pentax DSLR Discussion 2 11-04-2009 05:12 AM
All times are GMT -7. The time now is 05:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
