11-19-2010, 02:28 AM   #1
Pentax k-5 Debug mode
how can i enter in the debug mode / menu of the K-5
tried with MODSET.505 - [OPEN_DEBUG_MENU]
[DEBUG_MODE EN]
Turned camera on with MENU or delete button pressed
flash door open and closed - dosent work.
Does anyone know how it works ?
03-21-2011, 02:27 PM - 1 Like   #2
Antanico's Avatar
Hi Egelb,
edit the MODSET.505 in the following way as you missed a part in the second line:
[OPEN_DEBUG_MENU]
[SW_DEBUG_MENU EN]
[DEBUG_MODE EN]
[DEBUG_MODE DIS]
[RELEASE_AGING]
[SCRIPT_EN_MODE EN]
[SCRIPT_EN_MODE DIS]
Save it and restart the camera pressing menu and the card door opened.
Ciao
Ant
03-21-2011, 03:49 PM   #3
Can the version number be changed so that one can re-install an Older firmware?
03-22-2011, 05:00 AM   #4
Mikhail_Kriviniouk's Avatar
does not work for me
QuoteOriginally posted by Antanico Quote
Hi Egelb,
[OPEN_DEBUG_MENU]
[SW_DEBUG_MENU EN]
[DEBUG_MODE EN]
[DEBUG_MODE DIS]
[RELEASE_AGING]
[SCRIPT_EN_MODE EN]
Ciao
Ant
done all this. no debug menu...
03-22-2011, 02:46 PM   #5
LeFanch's Avatar
Location: Working in Norway, Bordeaux area when on time-off
I think I have read somewhere that the base name for the file is not MODSET for the K5.
And I do not remember reading the correct one either.
I think it is still being investigated. Am I mistaken?
03-24-2011, 12:00 PM   #6
Smeggypants's Avatar
Hi Egelb,
[OPEN_DEBUG_MENU]
[SW_DEBUG_MENU EN]
[DEBUG_MODE EN]
[DEBUG_MODE DIS]
[RELEASE_AGING]
[SCRIPT_EN_MODE EN]
Ciao
Ant
Modest.505 doesn't work here. Maybe this was for version 1.01 only. I have 1.03 installed
03-24-2011, 12:11 PM   #7
I also tried MODSET.505 last night without any success, tried with the card door open and pressing all the different button combinations, no luck. Version 1.03
Greg
03-24-2011, 01:03 PM   #8
Class A's Avatar
[OPEN_DEBUG_MENU]
[SW_DEBUG_MENU EN]
[DEBUG_MODE EN]
[DEBUG_MODE DIS]
[RELEASE_AGING]
[SCRIPT_EN_MODE EN]
I would not run that script.
"RELEASE_AGING" starts a sequence that artificially ages the shutter.
Also, even if the script had been started, it would have disabled the debug menu again.
The only two entries needed to open the debug menu are
[DEBUG_MODE EN]
[SCRIPT_EN_MODE EN]
Have a look at the respective Pentax Hack page.
It will tell you, among other things, that the base filename for the K-5 is not "MODESET" and so far unknown.
Just out of interest: Why do you want to go into the debug menu? As a K100D user I found it useful to adjust the AF calibration but K-5 users can do that without the debug menu. So I'm interested what the motivation is for a K-5 user.
03-24-2011, 01:22 PM   #9
Hi, Thanks for the feed back, I've been trying to set the AF fine adjustment on all my AF lenses and found that the +10 "Apply all" and the +10 "this lens only" was not quite enough to fix the BF on my Sigma 50-500. So before taking it in I wanted to play with what I hoped was the base setting for the phase detect AF system. I must admit that I'm also a bit confused as to weather or not the two adjustments "Apply All" and "Apply this Lens" are cumulative. The other reason for trying Debug is because it's there :<)) I have used it on my K200D
Greg
03-24-2011, 01:37 PM   #10
QuoteOriginally posted by gregmoll Quote
They are not.
03-24-2011, 01:48 PM   #11
Thanks, that's what I thought and that's why I was interested in getting into the Debug mode to try and add a bit more + adjustment. Maybe I should play with the three AF module screws on the bottom of the camera :<(((((
Greg
03-24-2011, 02:22 PM   #12
Class A's Avatar
They are called "screws" because you can easily screw up fiddling with them. Seriously, I wouldn't touch them unless you know exactly what you are doing. There might be one that just controls overall distance but in general you need a calibration test bed to set them to their optimal positions.
Does the K-5 show any BF on Pentax lenses? Normally you'd send in the camera plus lens but to the best of my knowledge Pentax only calibrates cameras in conjunction with Pentax lenses. If your camera shows a balanced performance with other lenses, it might be that the Bigma needs servicing.
03-24-2011, 02:42 PM   #13
Now AF Adjust
DA*16-50 needed +10.
DA*60-250 needed +5.
DA18-55 +4.
50-500 was still back focusing at +10, I guess it needs about another +5.
FA100 2.8 macro was -1.
Once I've got the Phase AF correct and in agreement with the Contrast focus I can fit my Canon Ec-b split focus screen and calibrate that.
Greg
03-24-2011, 05:08 PM   #14
Class A's Avatar
DA18-55 +4.
Seems like there is a positive bias in there which could be caused by the camera. If a camera calibration could knock off ~+6, you'll probably find working adjustment settings for all your lenses. You could send in the camera plus the 16-50 with a note that you need positive adjustments for other lenses as well (some exceeding the +10 minimum) and hence expect that they can recalibrate the AF module to need less adjustment for most of your lenses out of the box.
Of course it could be the case that your camera is spot on and all the lenses are off. Only a proper service agent is able to find out.
It would be interesting to hearing from your experience, should you choose to send the camera in.
03-24-2011, 07:45 PM   #15
Thanks, I'll do some more checking this weekend.
Greg
camera, debug, dslr, k-5, k-5 ii, k-5 iis, k5, menu, mode, pentax k-5
k-7 debug mode - how to enter Nass Pentax DSLR Discussion 17 01-17-2015 04:56 PM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
K10D Firmware 1.3 Debug Mode Unleashed! RiceHigh Pentax DSLR Discussion 148 10-01-2010 01:48 PM
How to access Debug Mode of Pentax K200 Thareen Pentax DSLR Discussion 28 04-08-2010 01:39 PM
Debug mode on K-x. ilya80 Pentax DSLR Discussion 2 11-04-2009 05:12 AM
All times are GMT -7. The time now is 04:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
