Originally posted by Wheatfield I can't speak to the "blur issue" with the K7 as in a few tens of thousand exposures, I never noticed a problem, so I would surmise that it is either
A: a non issue (bad shooting technique)
B: limited to a few bodies
It's not A, because the test is carefully designed and controlled. B would be quite a coincidence given that a number of different bodies were tested and all exhibited the same behavior.
The answer is "C" and "D":
C: it only shows up in certain circumstances, which are worth learning about if you really care about sharpness (although the advice is basically: use a really solid tripod, and keep the shutter speed relatively high)
D: the effect isn't earth-shatteringly huge (so to speak), and it's not a noticeable factor in many or most images.
But the important thing here is that
ALL cameras have quirks like this, both intentional design compromises and accidental issues. This one happened to get a thorough examination because someone with an engineering background noticed a particular problem and decided to track it down. This is a good thing in that when sharpness is paramount, it's something else you can know to correct for. It's bad in that people take it all out of proportion, leading to the worries that caused the creation of this thread.
The fact is, it's certain that the K-5 has some sort of problem like this. Ditto Nikon's D7000, and Canon's what-have-you. Probably lots of such problems. Some people may discover some of them, investigate, and maybe even write lengthy white papers. Other people will be oblivious and happily take pictures. Nothing wrong with either pursuit.
