11-22-2010, 07:14 AM   #31
ogl
ogl's Avatar
QuoteOriginally posted by Vaikis_ Quote
give link to FA77 examples ?
K5__0991_iso100.jpg - Альбом #1 - огл - Участники - Фотогалерея iXBT
UFRAW without any sharp.
with 60@0.8 in Photoshop
K5__0991_iso100-2.jpg - Альбом #1 - огл - Участники - Фотогалерея iXBT
---------- Post added 11-22-10 at 07:23 AM ----------
Light room 3.2
Pay attention that f8 is not the best aperture for FA77.
For FA*24/2 - F8 is the best.
---------- Post added 11-22-10 at 07:54 AM ----------
I think that problem is in bad copy of FA*24 in review....
11-22-2010, 07:58 AM   #32
here you can check real life K-5 + FA 77 exaples, in some shots I missed focus a little bit - it's my fault DNG files were converted in Lightroom 3.2 with default settings. You can select full size JPGs
http://www.flickr.com/photos/vaikis2006/sets/72157625266042285/show/
11-22-2010, 08:48 AM   #33
ogl
ogl's Avatar
Pentax K-5 with FA 77
Thanks a lot.
My modest advice:
When you use LR, put ALL NR to ZERO (if it's not high ISO), otherwise the photo will be less sharp.
Some photos at f2.2 are sharper than at 2.8
A lot of photos are misfocused...Why?
Can you show me the photo with the same IQ from K-5?
http://fotkidepo.ru/photo/132601/32162qXOjQehHIw/E9QALj3fZV/566217.jpg
11-22-2010, 11:03 AM   #34
QuoteOriginally posted by ogl Quote
Thanks a lot.
My modest advice:
After work it's very dark, I'll try at weekend Misfocused, because it was very dificult to shoot when hands are shaking after party
11-22-2010, 11:09 AM   #35
ogl
ogl's Avatar
I see...
11-22-2010, 12:44 PM   #36
ogl, I got my K5 a few days ago and my FA* 24mm should arrive tomorrow, I will do some tests at the weekend.
11-22-2010, 01:54 PM   #37
kent's Avatar
baisoki rezultatai, lyg sufokusuotu per arti nei rektu.
Seems like there is someones fault in these shots. Might be lens, might be camera
11-22-2010, 01:59 PM   #38
QuoteOriginally posted by kent Quote
bad hands, not camera or lenses !!! I know which photos are bad and which good. Just posted all. Maybe you can do better after big party with tekila )))
11-22-2010, 02:21 PM   #39
kent's Avatar
therefore i always leave SR switched on
11-22-2010, 05:29 PM   #40
falconeye's Avatar
Klaus from photozone says that K-5 has thicker AA filter than previous Pentax models...
Circular reference alert !!!
AFAIK, Klaus is awaiting his K-5 and commented on reports he saw elsewhere. Like comments from people like you, ogl.
We all shouldn't refer to non original information. As soon as Klaus does his first test, we sure will hear from him again. BTW, he's a 18-135 on its way
The previous model Klaus will compare with is the K10D.
11-22-2010, 05:37 PM   #41
Arpe's Avatar
is it prohibited to think and trying to understand why fa*24 is weak at k-5?
Is it not free forum?
wtf????
ogl, as soon as you compare, you need a benchmark, you have compared the lens on one camera to another, therefore you have benchmarked and tested.
Did I mention prohibition or restricting what you say? No. I was merely pointing out that what you said about not using a benchmark and testing was inaccurate.
Please carry on...
11-22-2010, 07:38 PM   #42
We have two copies of the lens, so we can do some tests next weekend as well!
11-22-2010, 08:19 PM   #43
ogl
ogl's Avatar
QuoteOriginally posted by infoomatic Quote
Oh...It would be very good if you'll show us the samples.
Anyway, please, prepare some DNG files.
11-23-2010, 09:10 AM   #44
Today I got my FA* 24mm f/2.0
My first impression was quite positive ...
You will find a 100% crop of the center of a test picture attached. It was tungsten light, shot wide open at ISO 100, 0.4 sec. Not too sharp, but I think OK for wide open. What's your opinion. Next tests will follow on weekend when I have time and better light ...
If you want to play with some DNGs (center/border resolution at f/2.0, f/5.6 and f/8.0), check out:
Index of /robert/24
11-23-2010, 09:26 AM   #45
The 2 I looked at suffered from severe camera shake. #655 and #657. If I were going to use that situation as a test subject for a wide open lens, I would boost the ISO. As they are, though we appreciate the effort, the photos don't help the reputation of the K5 with the FA*24 f2.0.
Edit.. After looking at the Exifs (your shutter count is in the low 400s btw), I see you used the timer to fire the camera, with a 2 second delay, suggesting a tripod or some other support. In the 655 photo I'm able to pull a sharp photo of the whiskey bottle but the FA31 next to it is way off for some reason. Same thing with #657 (which is even worse and looks like camera shake). #660, shot at f8, looks much better but with #662, shot at f5.6, the 31mm is out of focus again.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, review
I Am Weak... (LBA) ajuett Pentax SLR Lens Discussion 26 04-02-2010 12:46 AM
Two hunters in the sand ... not for you weak hearted Rense Post Your Photos! 13 08-13-2009 11:41 AM
too weak? not worth it? kewpie-o Pentax Camera and Field Accessories 7 07-31-2009 01:18 PM
I am so weak... need help!!! ACImages Pentax DSLR Discussion 3 01-03-2008 02:24 AM
please critique my work. what's strong, what's weak? konraDarnok Post Your Photos! 2 11-02-2007 02:53 PM
All times are GMT -7. The time now is 07:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
