11-21-2010, 05:29 PM   #1
K-5 strange behavior - rear dial wheel delay and battery issue.
I've had my k5 for three weeks now and notice a few small bugs other than those already mentioned in other threads.
1. My rear dial wheel will not respond immediately when turned. It sometimes takes a few clicks to begin whatever function asssigned. Does anyone else have this problem?
2. Even when there is charge remaining on the battery the camera will suddenly show zero or low battery, evertything will blink and everything stops working for about 2 seconds and then it goes back to normal. I originally thought this might be the byproduct of a new batty but it happened again today in the 4 th charge cycle.
Any thoughts? This is my first pentax (a100, d90, a550) and thought this might be a common issue?
11-21-2010, 09:57 PM   #2
Are you sure your camera isn't going into standby mode, and then the turning of the e-dial wakes it up? That's about the only explanation I can think of.
11-21-2010, 10:20 PM   #3
m8o
m8o's Avatar
Upgrade to the v1.01 bios. I think there was debug code in the v1.00 bios. A lot of things are a lot snappier in v1.01.
I found the battery meter to go from 2/3 to near zero whenever I went to live view or movie mode with the v1.00 bios. I didn't try either on the v1.01 bios yet to determine if this has changed.
11-21-2010, 10:26 PM   #4
The rear dial delay happens all the time. I take it that it's not common to have several clicks with no response? At first I thought it was a software bug or that it wss a normal delay but the front dial has no such lag
I did the 1.01 update and the problem persists.
The battery issue happens in regular p mode and not in live view.
battery, camera, charge, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Strange behavior from Tele-Takumar 300mm straightshooter Pentax SLR Lens Discussion 6 06-06-2010 05:56 AM
Matrix metering strange behavior... dlacouture Pentax DSLR Discussion 20 01-22-2009 08:20 AM
Strange *ist ds behavior trd300gt Pentax DSLR Discussion 1 11-14-2008 04:53 AM
Strange K10D + Pentax 18-250 behavior henzo Pentax DSLR Discussion 1 06-03-2008 05:54 PM
K100d built in flash: strange behavior Rafael Pentax DSLR Discussion 5 12-17-2007 03:02 PM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, part of our network of photo forums!
