Originally posted by Tom S. No I wouldn't think differently. Your camera broke within the first 2.5 months of ownership and was covered under the manufacturer's warranty. It was fixed and returned? What is the issue? If it was a car would you expect a new one to replace it?
The first part I quote may remain the case regardless of the 2nd part, and that's fine. But the second sentence is your own assumption. If it factored into your conclusion, let me set you straight tho I don't expect it to change your thinking. (why would you compare this issue and the manner warranties on cameras operate which give full replacements, to warranties on cars which do not operate that way! Such poorly thought-out premise does not help your argument. )
I dropped it, multiple times. No, it was
not covered by the manufacturers warranty. I spent a good deal more than the warranty cost to repair it. Used bodies cost far more at the time so the most cost-effective solution was to pay to repair mine.
I was mad at myself for not buying the warranty when I got the camera, and I would have been ahead if I got it. I got it on the K-5. If anything, that will at least ensure that the universe conspires to make sure I'll never do anything that requires me to need it this time.
Don't buy one. I hardly ever do on anything else. I won't say never, but almost never. But then again I never handle anything this complex, sensitive, nor put anything in such a high level of jeopardy as I do a D-SLR. So I probably will buy one on every D-SLR body I ever buy.
