Originally posted by CreationBear Rondec-- I keep going back to your foregrounds...the "tessellated" soybean leaves in the first and the splash of color in the broom sedge in the second just give these captures a depth I find unique. Anything you could tell me about your workflow on an image like this would be greatly appreciated--though of course I know there's no substitute for being aware enough to be in the right place at the right time.
Thank you for the kind words. To me, it is about light and subject. If I see what I am looking for, then I usually shoot a couple of multi-exposure bursts with slightly different framing. I usually have two primes on two K5s -- one is the DA 15 limited and the second is usually either the DA 40 or the DA * 55.
In post processing, I use Lightroom 4, presharpen with Nik Effects and then, usually will develop with presets that I have made in Color Efex Pro. Depending on the photo, I might try an HDR shot with HDR Efex as well, but usually the Color Efex image is what I go with. Once you have made presets, it is pretty quick to apply a "recipe" and then tweak it a little bit.
Focal length does make a big difference. This is one shot with the DA 15 limited and the same tree at sunrise.
