11-25-2010, 04:37 PM   #1
RonHendriks1966's Avatar
K-5 jpeg one * burst
Just did a test with my K-5 (and K-7).
With the K-7 you can make (with a fast card) in burst mode JPeg's from one star quality until the card is full. In practice this means 306 frames/minute, so 5,1 fps wich bring a datastream of 8,6 MB/s (1,69 MB average).
Same test with the K-5, 16 megapixel one * quality. This brings in one minute 238 Jpeg's, that's just under 4 fps and a datastream of 8,0 MB/s (2,0 MB average).
The K-5 takes even a lot of extra time for digesting the files, since after the minute there is stil a filled buffer that still has to be digested. The K-7 never fills up the buffer.
So what is holding the K-5 back?
- It can't be the SDHC card. I used a class 10 card wich is much faster (at least 13-14 MB/s). Even when the K-7 would use the maximum writingspeed then with the K-5 you would expect 255 pictures to written away to come to the 8,6 MB/s.
- When I count the pixels then it doesn't match up eather. You would expect then at least 274 frames when the K-7 was working at it's maximum speed.
Where does it come from? Someone an idea?
- Is it the PRIME II processor different (don't expect that)?
- Is it the A/D conversion that is with the K-5 onboard of the sensor instead of the separate A/D conversion in the K-7?
11-25-2010, 04:57 PM   #2
bobmaxja's Avatar
Have you install the new firmware 1.01??
11-25-2010, 05:03 PM   #3
QuoteOriginally posted by bobmaxja Quote
Good question and YES.
11-25-2010, 05:06 PM   #4
hcc
hcc's Avatar
It would be very helpful if you could repeat the same exact tests, with the old firmware and the new firmware. Any difference ?
I also assume that you switched off all forms of in-camera PP. Correct ?
Look forward to see your results.
The K-7 is amazing in Hi continuous shooring with JPEG one-star and I would hope that the K-5 does as well.
11-25-2010, 05:08 PM   #5
Any post-processing that could slow things down? Like lens correction?
11-25-2010, 05:58 PM   #6
Wheatfield's Avatar
Maybe the file size?
Just a thought.
11-25-2010, 06:17 PM   #7
(16*(2^14))/(14.6*(2^12))
4.38356164383561643835
perhaps where it all starts? (hint: the buffer is not holding (only) jpegs..)
11-25-2010, 06:24 PM   #8
vievetrick's Avatar
Do you have k5 set to include your copywrite info?
11-25-2010, 07:30 PM   #9
QuoteOriginally posted by RonHendriks1966 Quote
Claas 10 card should be 30MBs a Sec. At least the Sandisk class is
11-25-2010, 08:34 PM   #10
QuoteOriginally posted by Pentax Lover Quote
Class 10 cards just have to be a minimum of 10mb/sec. Sandisk's fastest SD card has "Extreme speed at up to 30MB/second read/write". Note that is not minimum, but maximum. It could be only 10mb write and 30mb read and still make the claim of being class 10.
11-25-2010, 08:49 PM   #11
Raybo's Avatar
Just a thought.
I agree!
11-25-2010, 10:46 PM   #12
is one star faster than 5 star? I suppose compressing the jpgs heavily is faster than writing larger files?
11-25-2010, 10:53 PM   #13
FYI I tried shooting at 2MP and I still got about 34 JPEGs - so I can't help but think that the camera just throws unprocessed data into the buffer.
11-26-2010, 12:02 AM   #14
1080p video is 2mp, so may as well just film at 25fps
11-26-2010, 01:51 AM   #15
Not if I want to focus in between, lol. In any case, the point is that Pentax has failed at programming the buffer. Hopefully they'll further improve on it.
camera, card, conversion, dslr, k-5, k-5 ii, k-5 iis, k-7, k5, mb, minute, pentax k-5
Nature About to Burst............ eaglem Post Your Photos! 3 10-07-2010 10:34 PM
Burst mode Orli Troubleshooting and Beginner Help 3 02-22-2009 06:20 PM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
Burst Mode shefaet Pentax News and Rumors 42 01-25-2008 08:50 AM
All times are GMT -7. The time now is 07:28 PM. | See also: NikonForums.com, part of our network of photo forums!
