View Poll Results: Is your K5d sensor stained?
YES - There are stains on my sensor 19356.43%
NO - My sensor has no stains 14943.57%
Voters: 342. You may not vote on this poll
Closed Thread
12-11-2010, 11:38 AM   #301
QuoteOriginally posted by janneman Quote
My wall was tooo dirty totest so I made an appointment with a painter....
However, here is my sky:
f32:
Also weird gradient but I have a new laptop with newlsy installed LR 3.3 so that may be the culprit.
HI jenneman
it looks like your K5 is slightly affected; mine shows same pattern from f11 onwards so I returned it for an exchange.
12-11-2010, 01:09 PM   #302
TLiivo's Avatar
S/N: 3885790 All clear!!
12-11-2010, 10:36 PM   #303
sterretje's Avatar
SN 3832134 with stains; confirmed by dealer
Will hear next week of plan of action
12-12-2010, 09:19 AM   #304
ogl
Banned
There is info from Pentax dealer that the problem is in SONY'S QC. I've found it in any Pentax forum. But, forgot a link.
Could anybody give a link?
The sensor is usually shipped to the customer as WHOLE SET with AA filter. There are no any equipment at any DSLR factory to put AA filter to sensor. The sensor set is made under DSLR's manufacturer demand.
12-12-2010, 09:27 AM   #305
No stains
No stains s/n 3823889
12-12-2010, 11:49 AM   #306
DJP
DJP's Avatar
Well, I have sensor stains too. s/n 3847744. I bought it from Amazon, through H and B Digital. I sent an email to the seller today, hopefully they'll respond soon. I have had the camera just over 1 month. I just saw this thread today and did some testing and sure enough there are stains right in the middle of the sensor.
Anyone know the best way to get it replaced? Through the seller (H and B Digital), Amazon or Pentax???
12-12-2010, 04:52 PM   #307
falconeye's Avatar
QuoteOriginally posted by ogl Quote
Where did you hear so?
I think you confuse the AA filter with the microlens assembly.
The AA filter (and on top of it, the IR filter with ultrasonic antidust vibration) is as hard to assemble as glass. And is replaced by some third party companies offering this as a service. Around 450 Euro for the K-5 btw...
There was a post mentioning a Pentax dealer (the Australian distributor) that the problem was with the supplier of the AA assemblies. But that post turned out to be a speculation on the dealer's side. And Sony Microelectronics isn't supplying AA filters.
So, to me it looks like you're just spreading unreliable information here. But that wouldn't be a first for you, right?
12-12-2010, 10:09 PM   #308
ogl
Banned
Pentax factory at Phillipiness doesn't put AA filter to sensor. It's assembly factory.
They assembly cameras from component parts from various suppliers.
No any fine work with sensor.
Do you think that Pentax gets sensor naked from Sony and then they put all another stuff for sensor?
12-13-2010, 05:11 AM   #309
Minulla on helminauhaa anturin kuvassa.
Numero 3825202
12-13-2010, 05:15 AM   #310
falconeye's Avatar
I said a dozen times now what I think ...
Sony Microelectronis supplies a CMOS sensor packed into a ceramic ball grid array housing (BGA) which has a glass cover plate. It has soldiering points on its underside and a glass window on its top side and is a gray ceramic otherwise. This is what is called a "chip". Maybe, read a bit about it.
A "naked" CMOS sensor would be called a die. Because the microlenses and CFA filter is microaligned to the die, it is attached directly to it and is embedded into the chip. But that is NOT the anti alias filter assembly we are talking about.
Pentax soldiers the BGA onto their shake reduction daughterboard PCB. That's typically outsourced to a PCB manufacturer who then does the soldiering too. It's an automated process and I assume Pentax does it somewhere near Tokyo. Or they have own machines for this.
Maybe, they preassemble the entire SR module prior to sending it to the Philippines. It's easy: After soldiering, you clean, glue the AA filter assembly and screw two metal blades to the bottom/top of the assembly. It is at that cleaning step I image the contamination is happening. And this is entirely Pentax' domain.
12-13-2010, 06:24 AM   #311
ogl
Banned
So...Is it Pentax fault?
12-13-2010, 07:04 AM   #312
It can answer only Pentax, I don't think that you or falconeye knows exactly where AA filter assembly is glued. Maybe it's outsourced by Pentax to other company.
12-13-2010, 07:21 AM   #313
No stains, only 2 small dust spots (barely visible at f22).
#3913367
12-13-2010, 08:44 AM   #314
No Stains, Maybe A Dust Bunny?
Hello,
I am new to Pentax and loving the K-5. (Nikon FM user and Canon EOS 3). I am also new to the DSLR world. Here are a couple small files showing what I guess is a dust spot? The in-camera dust remover didn't do anything and I am waiting for my air bulb to see if that jars anything loose.
What do the experts think? I sandwich dust ball or on the surface? These are at f22. You can see a less visible version at f16 and at wider apertures you don't notice it.
I don't think it is to hard to pick out the spot... (3 o'clock)
Thanks
12-13-2010, 09:18 AM   #315
Joined the infamous "string of pearls" club...
Greetings to all Pentaxians,
I've bought a K-5 body in Romania.
After doing some macros and constantly wondering why a centered string of dots appeared in every picture I've taken, I finally read this thread.
Went today to the shop, talked with the shop owner - he said I'll get an answer tomorrow about a possible replacement of the K-5 body.
Left my camera to be replaced (or repaired, but I have some strong doubts about that ).
It's very embarrassing to not have my K-5 available for the moment, considering that it was my only (semi-)professional camera I've got left.
Cheers,
Even
Closed Thread
camera, database, dslr, k-5, k-5 ii, k-5 iis, k5, k5d, pentax, pentax k-5, poll, sensor
Some K-5s shipped with stains on the sensor/AA filter? Peter Fang Pentax K-5 292 03-06-2011 01:57 PM
% of k5 showing stains on sensor? stormcloud Pentax K-5 2 12-05-2010 08:41 PM
Full Frame Fisheye Zoom F and 43 Limited on K5D (Sample Photos) RiceHigh Pentax SLR Lens Discussion 7 10-09-2008 10:48 PM
Pentax K20D, K5D, or K1D (or both a K5D and a K1D)? stewart_photo Pentax News and Rumors 42 01-04-2008 02:45 AM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
All times are GMT -7. The time now is 10:44 AM. | See also: NikonForums.com, part of our network of photo forums!
