12-07-2010, 07:26 PM   #1
New ACR Lens Correct vs K-5 in Camera Correct
I see more Pentax lens profiles are now available in ACR.
Lens correction can be done to RAW files in my Photoshop
OR
Lens correction can be done "in camera" w/my K-5.
For the lens corrections that seem to be duplicated between "in camera" and ACR - distortion and chromatic - any ideas or opinions as to which lens correction you would use?
The ACR RAW lens corrections have control sliders, and obviously there is a lot more control. The "in camera" lens corrections seem to suck a lot of processing power and delay the display of the just taken shot on the LCD.
Just looking for other peoples' thoughts on this - if any.
12-07-2010, 07:46 PM   #2
alexeyga's Avatar
In-camera only applies to JPG and it drastically slows down the camera... RAW is your friend..
12-07-2010, 09:29 PM   #3
The option to turn lens correction on and off is available on the lcd info screen for RAW as well as JPG. I'm quite certain the processing takes place in RAW also as processing is slowed way down in RAW also.
12-07-2010, 09:43 PM   #4
alexeyga's Avatar
You're probably in RAW+JPG... because on mine, in RAW only lens correction is grayed out... The only correction that is applied to RAW files by Pentax cameras is Noise Reduction at high ISO...
Another benefit of applying the correction to RAW files in ACR is that you can vary the degree of correction... for instance, I almost never completely de-fish images taken with a fisheye keeping them at ~35-40%... that's just the way I like it...
12-07-2010, 09:57 PM   #5
Miguel's Avatar
The lens corrections found in ACR and Lightroom were developed via collaboration between Pentax and Adobe. The few random tests I've performed look superb, especially the DA Ltd 15mm and 21mm models. I would really like the DA 12-24mm to be included in the future.
One note to Lightroom users: using the lens corrections tended to slow down LR 3.2. I have not used v3.3 enough to determine if Adobe has "fixed" this. So if using lens corrections still bogs things down, save it for the last step in your workflow.
M
12-08-2010, 12:08 AM   #6
I only see lens corrections for pentax 645 lenses... no DA limited corrections in the list... do you need to download these separately? (in light room 3.2)
12-08-2010, 12:38 AM   #7
You need LR 3.3
12-08-2010, 12:59 AM   #8
awesome, downloading now, annoying that its a full download / uninstall / reinstall and not just an in app patch.
didnt need re registering though so that is good!
and now i have corrections for every lens i own, awesome
12-08-2010, 01:11 AM   #9
ogl
ogl's Avatar
QuoteOriginally posted by WerTicus Quote
LR 3.3 + K-5 = awesome result. sharp. even moire visible.
it says that AA filter is not strong. VERY cool colours.
K5FARI00100.jpg - Альбом #1 - огл - Участники - Фотогалерея iXBT
http://fotkidepo.ru/photo/132601/32162qXOjQehHIw/E9QALj3fZV/571073.jpg
12-08-2010, 02:05 AM - 1 Like   #10
QuoteOriginally posted by emblemex Quote
When you shoot RAW, the camera applies all JPG processing to create the JPG that's embedded in the RAW file. These are the images you see when reviewing pictures in-camera. This is why histogram and highlight warnings you see in-camera are not necessarily accurate as they are the result of this processing (including compression or parts of the histogram for contrast changes, highlight and shadow clipping). Lens corrections are the same, i.e. they are applied on the embedded JPG but the RAW data is left untouched by them.
Wim
12-08-2010, 07:01 AM   #11
alexeyga's Avatar
Big disappointment is that there's no profile for the DA 10-17 yet... But they are going in the right direction nonetheless...
12-08-2010, 11:00 AM   #12
QuoteOriginally posted by Ishpuini Quote
Wim
Tks for your reply. This makes sense to me.
12-08-2010, 12:20 PM   #13
macTak's Avatar
QuoteOriginally posted by ogl Quote
Is that for PEF, DNG, or both?
camera, control, correction, corrections, dslr, k-5, k-5 ii, k-5 iis, k5, lens, lot, pentax k-5
Is this the correct lens for my KX? Touchwood Troubleshooting and Beginner Help 3 10-08-2010 07:34 AM
Correct Takumar Lens case Peqpete Pentax Camera and Field Accessories 4 08-06-2010 09:25 AM
How to correct Wb trishytee Photographic Technique 12 05-10-2010 06:40 PM
Which is correct? Aristophanes Pentax DSLR Discussion 2 09-30-2009 09:36 AM
Correct procedure to change a lens to reduce dust dingnecros Photographic Technique 26 07-27-2007 11:23 AM
All times are GMT -7. The time now is 10:41 AM. | See also: NikonForums.com, part of our network of photo forums!
