12-09-2010, 10:47 PM   #1
Why does Pentax limit you to 5 exposures when bracketing?
It seems arbitrary... Is there a technical reason? Seems like 7 or 9 exposures like the 5D Mark II is what the K5 deserves...
12-09-2010, 10:49 PM   #2
JohnBee's Avatar
The question as to why comes to mind...
On the K20D. in most cases I find myself most commonly using 3 to 4.
And if we consider the K-5's phenomenal DR, I suspect that no. will be even less if any at all.
12-11-2010, 02:30 PM   #3
nulla's Avatar
QuoteOriginally posted by JohnBee Quote
Good point John
I am finding 3 as being suitable... I am using it a lot as test and trial and have found that by assigning this option to the RAW button its a breeze to use.. great feature
cheers
Neil
12-11-2010, 02:54 PM - 1 Like   #4
panoguy's Avatar
That's a rhetorical question to some degree, since it's only a "limit" if you need more than 5. I personally need more than 5 for my HDR panos (for 3D lighting), but that's a fringe case, and I stick with Pentax because I can also ExpComp two sets of brackets to cover the range I need (and toss the extras).
Notice I said "to cover the range I need" - the number of brackets in the AEB is only part of the equation. Consider this table of AEB by model/mfr which includes the net total ev that those brackets can cover. Pentax is doing quite well in the AEB area, especially given the DR of the sensor and the price of entry compared to an M9 or D3. For some HDRs, sure I'd like to press the shutter once to get 7 or 9 brackets at 3ev steps, but not enough to buy a Canon!
12-11-2010, 03:24 PM   #5
stanic's Avatar
QuoteOriginally posted by panoguy Quote
the chart claims K-x to have max. EV step of 1,5 EV, but I can dial in a -3, 0 and +3 steps in bracketing mode
am I missing something (or the chart)?
12-11-2010, 03:46 PM   #6
bracketing
i'm thinkin if you need more than 5 you prolly should go back to a compact
12-12-2010, 10:02 AM   #7
Trig's Avatar
For this reason alone, I'd love to have up to 9. Doesn't seem like it would be that hard to do for Pentax, then again, I am not a firmware guy
Yeah, yeah, I know it is easy to do manually with some Ev comp, but have 9 easily fired off would be sweet.
camera, dslr, exposures, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Pentax K-5 - buffer limit problem !!! gubak Pentax K-5 19 11-22-2010 09:19 PM
Why do Pentax limit sales of the 1.7x AF TC PMunks Pentax SLR Lens Discussion 23 11-06-2010 12:49 PM
Bracketing on Pentax 67ii rickbehl Pentax Medium Format 12 07-30-2010 12:58 PM
Question Pentax Equipment Limit Fl_Gulfer Site Suggestions and Help 1 09-18-2008 02:16 PM
Pentax and long exposures ftpaddict Pentax DSLR Discussion 10 06-27-2008 11:27 PM
All times are GMT -7. The time now is 01:57 AM. | See also: NikonForums.com, part of our network of photo forums!
