12-12-2010, 06:47 PM   #1
the only k-7/k-5 "design" bug
i have had my k-5 for about a month (now in for replacement).
when the k-7 came out, i was one of the few "weird" ones pointing out that polycarbonates are simply better for shells, and metal alloys are simply outdated. everybody wants magnesium alloy. i can't figure out why?
the k-5/k-7 feels great, i come from a k20d, and i feared it would be small for me (especially as i have been using the grip on the k20d now for a while). it is small, yeah. but they designed it well, i don't mind a bit. very impressive. however.. it's COLD! the difference from my "decadent" polycarbonate body k20d is immense. my hand will freeze on this thing instantly. and i only had the time to use it for short periods, in mild sub zero temperatures in the city and nearby (i normally go to the mountains, where it's a whole different story). i am also worried this will affect battery life in the cold, as the battery will drop in temperature much quicker (but that reamains to be seen), the k20d is doing very well in the cold btw (except some weird (few) deffective units, which showed banding in bellow zero temperatures, but that's a different story), i can conffidently say that the "-10 resistant" rating for the k-7 was merely a formality for pentax (and probably not only), a nice one at that, though.
any "cold weather" shooters here feeling the same?
nanok-my-k20d-isn't-going-anywhere-soon
12-12-2010, 07:00 PM   #2
it has been winter here for a while now. I would say that my K-5 has been below -10C for half of the month that I have had it. No problems noted. I just wear gloves when handling in the winter.
Jack
12-12-2010, 11:27 PM   #3
imtheguy's Avatar
I certainly don't have your kind of winters being here on the ocean, but its been below freezing for about 5 of the last 7 days. I use hunting gloves with grip surface, finger holes and little zipper pockets on the back of the glove made for small heaters. My point is your battery more than your hands so I keep a battery in the back of each glove since they seem to die quickly in below 0c temps.
Guess I never went out bare-handed and noticed the diff between my k20d and k-5.
12-12-2010, 11:45 PM   #4
Yes, it gets cold. But still, its built to stand the cold to.
The lenses however is another story. They get really really cold
12-13-2010, 03:24 AM   #5
Can't compare to k20 but i had no problems using k5 in sub zero temps barehanded. and yes you should keep your spare batteries in inside pocket of your jacket.
12-13-2010, 10:07 AM   #6
S_V
У меня не было проблем с k-20d на морозе -32 часов 6-8!!!!Главное избегать конденсата!
battery, camera, dslr, k-5, k-5 ii, k-5 iis, k-7, k20d, k5, pentax k-5, story, temperatures, zero
Interesting "bug" found? robw Pentax K-5 11 12-12-2010 06:26 PM
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 08:12 PM. | See also: NikonForums.com, part of our network of photo forums!
