12-14-2010, 07:04 PM   #1
K-5 and LR3
Oh my - what's the difference between a PEF in the K-5 and in the 20D and other Pentax RAW files? I got my K-5 yesterday. I am trying to load my K-5 images into LR and it says the preview is not available. It's "copying and importing", but the folder is empty! Both in LR and on the computer. Is LR3 K-5 compatible? I've always loaded PEF files from K20D, K100D, K2000D, & *ist-D with no problems.
12-14-2010, 07:41 PM   #2
shoot dng problem solved
lr 3 will probably need an update to work with the k-5... 3.3 is out just recently have you tried that?
12-14-2010, 07:45 PM   #3
Yes 3.3 is supposed to work with K-5 PEF.
12-14-2010, 07:49 PM   #4
m8o
m8o's Avatar
QuoteOriginally posted by sandpiper6 Quote
... a few million extra pixels each with a few extra bit-depths of detail!
12-14-2010, 07:55 PM   #5
QuoteOriginally posted by Matt Miller Quote
I sure hope so. I had 3.2. I have 3.3 installing while we speak. I sure hope it is compatible! I have homework due tonight. I've already filled a 4GB card with K-5 raw files - just today!
I got them copied to my computer via Bridge, but the homework requires me to use Lightroom's Print module to create contact sheet pdfs. I suppose I could create contact sheets in CS5 and print as pdf. Gonna be a long night...
12-14-2010, 08:00 PM   #6
m8o
m8o's Avatar
... it is; you really need not worry. You'd be the only one it doesn't work for for some reason if not.
12-14-2010, 08:02 PM   #7
Thanks for the replies!!! 3.3 was a fix. Panic attack averted.
12-15-2010, 03:59 AM   #8
Also 3.3 has more lens corrections for DA , Limited, FA limited and DA* glass.
12-15-2010, 07:56 AM   #9
m8o
m8o's Avatar
Much to my chagrin, I discovered the larger lens selection is only the case if you're processing RAW ... which is what I do 99% of the time anyway ... until I decided to use K-5's in-camera HDR. I was surprised to find a different list of Sigma lenses displayed whether I was handling a JPG file vs. a RAW file.
camera, dslr, files, k-5, k-5 ii, k-5 iis, k5, lr, lr3, pef, pentax k-5
No autoID for DA-15 Limited in LR3 tram57 Pentax SLR Lens Discussion 4 12-17-2010 07:45 AM
Using LR3 with Elements 6 eccs19 Digital Processing, Software, and Printing 19 11-21-2010 02:55 PM
LR3 LENS PROFILE FOR DA 15 mm philippe Digital Processing, Software, and Printing 0 10-15-2010 09:25 AM
LR3 or Elements with Topaz? JHD Digital Processing, Software, and Printing 10 07-19-2010 03:40 PM
Anyone uses watermark feature in LR3? ducdao Digital Processing, Software, and Printing 0 06-24-2010 06:43 AM
All times are GMT -7. The time now is 07:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
