Hi all..
After all the heated discussion, can someone recommend a generic k5 battery that works well? I recently get a k-5 and would like to get at least one extra battery. Please provide link to the battery! Much appreciate!
edit:
OK, I did some search on Adorama, BHPhoto and other places.
The Pentax OEM is $37.52 (rated 1860 mAh) at BHPhoto:
http://www.bhphotovideo.com/c/product/634906-REG/Pentax_39830_D_LI90_Recharg...n_Battery.html
The Flashpoint replacement is $9.95 (rated 1550 mAh) at Adorama:
http://www.adorama.com/IBYDLI90.html
The Power2000 replacement is $17.95 (rated 1700 mAh) at Adorama:
http://www.adorama.com/PQACD305.html
The Pearstone replacement is $19.95 (rated 1700 mAh) at BHPhoto:
http://www.bhphotovideo.com/c/product/645340-REG/Pearstone_D_LI90_D_LI90_Rec...n_Battery.html
The 'Noname' replacement from Amazon (Cameta Camera) is $14.95 (rated 1700 mAh):
http://www.amazon.com/Battery-1700mah-Replacement-Pentax-D-LI90/dp/B002MN94PU
Another 'Noname' replacement from BestBatt is $8.90 (rated 1900 mAh !!):
http://www.bestbatt.com/Pentax_D_LI90_Li_Ion_Rechargeable_Battery_p/bbdli90.htm
So, in general, the Pentax OEM hold more juice (1860 mAh) than other replacement. Of course, except the one from BestBatt, which rated 1900 mAh! higher than Pentax OEM! and its only $8.90. So this is probably the best value if it is true. Now.... have anyone buy from them?
Lee
