Originally posted by jpzk ...I am hoping someone would provide some "tips" on how to test the K5 for AF in dimmed Tungsten light when I go to the store on Friday this week (December 31st).
This would seem like a neat, pocketable method:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/126249-how-int...ml#post1307972
The best part of the above IMO is that you not only see if there is a problem but whether it is back/front focus. The DA 16-50 should show the symptoms (if any) clearly at 50mm, f=2.8 and a short distance (~0.5m). In general you'll want minimum DOF for testing, and that comes with large aperture/long FL/short subject distance.
I would assume that the issue this thread is about, that is, different focusing under low artifical light vs. daylight affects all K-5s, but you never know. Testing for FF/BF with the fast lenses you have makes sense in any case. This way, you might avoid sending in the body for adjustment and/or getting a lens body combo where you run out of adjustement range. If you have other fast lenses you could use in the circumstances consider bringing them too.
It seems that my Tamron 17-50 1:2.8 front focuses with the K-5 in any light and that I would need a bit more adjustment for best results: knowing what I know now I would have done well bringing that in when I went shopping. Luckily I also have a stained sensor, which should mean a replacement anyway ;-)
