Originally posted by Jyrkira With K-7 I did not need to rotate camera 90 decrees to see image quickly
Hi
Sorry, I don't understand your logic. With the old auto rotation system, If you don't need to rotate the camera 90 degrees to view a portrait picture, well then just do the same with the already in portrait mode locked in system, what is the difference. You do the same, don't you? I don't know how I can make you understand this.
Lets call the the K7D auto rotation system the "old system" and the new lockable portrait mode of the K-5 the" new system."
In the "old system" you say you don't need to turn the cam a full 90 degrees to see the portrait shot in full. O.k., with the "new system" you don't need to do this either, its already there, turn the cam any degrees you like. You can even view it without turning the cam if you put your mind to it.
And then you write:
"And it was quick to rotate the camera if I wanted to see a portrait image bigger"
Well again I can't see the logic in what you are saying here. If you want to see the locked in portrait picture with the "new system" quickly, you do the same, don't you? You turn the camera! The picture is already there, you turn the camera for crying out loud, this way or that way! The picture is already there for you to view!
Just think about it: the old K-7 auto rotation gimmick has
no benefit, if anything it is a hindrance. The PENTAX engineers recognised this and have done away with it because it makes zero sense. They have retained the auto rotation feature for the status screen though because here it does make sense to auto rotate.
Greetings
