12-20-2010, 09:58 AM   #1
Is high speed memory worth it?
Hello everyone,
Just trying to figure out what memory to get for my new camera! Does the 200x memory give a tangible speed increase over 166x? Or is the buffer going to fill up before it ever becomes a factor?
Since the 166x memory is about half the price per GB.. I'm trying to figure out if the extra speed is worth the money...
12-20-2010, 10:12 AM   #2
Tom S.'s Avatar
The need for memory speed is very dependent on what it's being used in and what it's being used for. To obtain a more specific answer, please tell us both!
Example of 'used in' would be what brand/model digital camera.
Example of 'used for' would be the kind of files you are going to be using, or more specifically, their average size.
12-20-2010, 10:53 AM   #3
yes.
I assume you are talking about SDHC card.
12-20-2010, 11:04 AM   #4
some say that class 6 sdhc is all the speed you need for shooting full hd videos.
i havn't noticed that much difference between my 4 years old 1gb scandisk sd and kingston 16gb class 10 sdhc.
12-20-2010, 11:39 AM   #5
Oooops...
Primary purpose would be shooting raw on a K5... Trying to figure out if the amount of frames I'll be able to shoot before the buffer fills up will be significant...
12-20-2010, 12:10 PM   #6
Don't take too much notice of 166X and 200X etc, in practice it doesn't mean much. Have a look at:
Rob Galbraith DPI: CF/SD Performance Database
I bought a Sandisk Extreme 30Mbs Edition to shoot RAW on my K5
Vic.
12-20-2010, 12:25 PM   #7
QuoteOriginally posted by Jinxed Quote
Oooops...
Actually it wouldn't necessarily (at least entirely) have an affect on how many photos the buffer can take. It is flushing the buffer to the memory card where the write times become longer or shorter. I have a couple of sandisk extreme III 8gb class6 cards, but bought 2 patriot LX 16gb class10 cards since the K5 files are quite large. I've found no noticable difference between either cards, despite their different class rating.
The truth behind the class rating is that manufacturers have been making cards even beyond class10 speeds well before class10 was around - this is because class10 is only a recent edition, so earlier cards could only be labelled as class6 despite being faster.
12-20-2010, 02:33 PM   #8
Banned
As mentionted with class 6 you can do everything. Only if you shoot frequently RAW in burstmode then you will have advantage for a faster card. Not so much for taking more pictures before the buffer runs full (maybe one or two extra) but for flushing the buffer empty to your card.
12-20-2010, 02:56 PM   #9
amoringello's Avatar
A few shots on the camera or movies, probably not so much.
You'd probably notice a bigger difference when you get home and download the images to your computer.
Sadly, not all readers are created equal. My newest (and not cheap) card reader by Sandisk is slower than my class 6 card can handle. Much faster using the EyeFi dongle.
And of course, I would love to be able to have a UDMA SD card reader. :-)
12-20-2010, 08:53 PM   #10
dosdan's Avatar
I don't believe so. but if it makes you more comfortable, do it. I noticed no burst performance difference with my K20D between a cheap Class 6 and Transcend Class 10 (still fairly cheap) SD card. But the K-5 is much faster. So, maybe.
See: https://www.pentaxforums.com/forums/accessory-memory-articles/119185-measurin...ml#post1231890
Dan.
12-20-2010, 11:45 PM   #11
pentax user's Avatar
wait for sdxc
12-21-2010, 01:47 AM   #12
hoanpham's Avatar
QuoteOriginally posted by pentax user Quote
wait for sdxc
sdhc can handle 2T bytes, but sdhc hosts (cameras) will only support the SDXC cards which use UHS104 speeds, not maximum speed for sdxc. 16G can hold 600+ images, but i m still want a 64G sdhc ;-)
12-21-2010, 05:19 AM   #13
Tom S.'s Avatar
Oooops...
This is just my own opinion, but for shooting RAW with the K5, I would go with the fastest card you can afford. RAW files are something like 30MB in size, and while the camera's buffer may handle shooting/storing them, if you load up a bunch on a card, downloading will be time consuming. I recently purchased some class 10 cards and the download time on them is remarkable. Also, there is a rumor that a firmware update may raise the K5's continuous RAW rate.
12-21-2010, 12:55 PM   #14
I went with class 10 mem... The extreme III is just too expensive for the difference...
12-22-2010, 12:35 PM   #15
Minulla on Transcend 10 32GB se ainakin on selvästi toimivanpi, kun muut hitaamat. Eikä takeltele sisään laittaessa tai poisottaessa.
camera, dslr, figure, k-5, k-5 ii, k-5 iis, k5, memory, pentax k-5
Example of AF, DR, high ISO and high shutter speed on K-5 benisona Pentax DSLR Discussion 17 11-30-2010 02:25 PM
Will Class 10 memory card help with preview speed (K-7)? skyredoubt Pentax DSLR Discussion 3 10-18-2010 07:14 PM
memory card speed jani Photographic Technique 2 06-01-2008 02:23 PM
Memory Card Speed Advantage? spanky12 Pentax DSLR Discussion 5 11-24-2007 10:47 AM
K100D Super memory card speed Antitrust Pentax DSLR Discussion 3 09-10-2007 09:32 AM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
