Originally posted by WerTicus there is tons of difference between these cameras, they are not even in the same league features wise... you do have to dig a little deeper than the spec sheet to find this out though...
d7000 has:
1fps less shooting speed
half the buffer size
lesser auto bracket options
crap button layout
no shake reduction
no weather sealing
plus more (less)
yep, some neat K5 features:
horizon correction - sounds phony, but i noticed a lot less processing on my part because of this,
real time roll and tilt display, i suppose to help with perspective distortion and pano setup
built-in interval shooting - which can also be used to set up a custom delay timer, forget 2sec, 12 sec, how about hours or more
multiple images - can help with smooth water when one doesn't have an ND filter,
hot pixels - you can map it out yourself
bracketing options (repeat) 2,3,5 vice just 3 on D7000.
built-in hdr - for those than want it on the fly
I suspect we will see a Nikon D400 that will try to out-feature and out-spec the K5, but it will be come at a higher price. Pentax didn't have to worry about carving out sales from another model niche, because pentax only has 3: 645D, K5 and Kr.
