Originally posted by kryss Welcome,you and a number of us would like to have remote control of K5 but Pentax quietly removed tethering from K7 and did not include it in K5.There is some rumour it may be introduced in an upgrade to the 645D(no,not even this $10000 body has tethering capability)when and IF this happens it may be available in K5.this is the only reason I neither bought K7 or K5.
I'm confused.
I thought the OP was after a remote shutter release using RF. "Tethering" from what I know is a totally different animal.
As a remote shutter release, the Yongnuo 602 works with K10D and K7. It's hard to imagine it does not work with K5.
Originally posted by peterh337 I know remote control and remote trigger are different things, but can anyone recommend a remote trigger product for the K5?
I see the K5 uses what looks like a 2.5mm jack plug lead but I haven't yet found a product which specifically claims to work with the K5.
I bought a RF-602 radio flash trigger, which works perfectly with a Canon 7D (as claimed) but doesn't work with the K5 at 1/180 "X". It also works fine with the 7D as a remote trigger with the supplied Canon trigger cable, but they don't seem to do a Pentax trigger cable.
The Pentax cable does exist (see photo above). I have 2 copies of the RF-602 for Pentax.
It's true that as a remote flash trigger, the RF-602 does not sync properly at 1/180 sec (black band at the bottom of the photo). But if you "half press" the button on the transmitter (you can use a piece of tape for this purpose), it will sync at 1/180 sec. You'll pay for the extra consumption of battery, however.
