12-30-2010, 02:19 PM   #1
Can't display control panel.
When I press the info button the status screen is displayed, when I press it again a blank screen is displayed, when I press it again the status screen is displayed again. I am unable to display the control panel, have I gone wrong somewhere?
I should add that I only got the camera today.
12-30-2010, 02:26 PM   #2
Ira
QuoteOriginally posted by velvia Quote
Manual. Manual. Manual.
But have you hit the menu button yet!?
You really, REALLY have to read your manual. Everything is laid out there pretty clearly.
12-30-2010, 02:43 PM   #3
Take the camera out of green mode. Most settings in Green Mode are not adjustable so no need for the control panel.
12-30-2010, 02:47 PM   #4
Actually Ira, it isn't always that clear but it's there if you no where to look. The OP's problem for instance is not addressed in the control panel section but in the green mode section.
12-30-2010, 03:12 PM   #5
QuoteOriginally posted by JeffJS Quote
Thanks for that, the mode dial was set on green mode, I changed that and now I can display the control panel. I have read, and am continuing to refer to the manual. I just didn't realise that the green mode, which I wont be using, would have that effect.
camera, control, display, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, press, screen, status
Anyone try the Sunpak Flat Panel FP-38 Flash? Ira Flashes, Lighting, and Studio 6 12-16-2010 02:44 PM
Info on LCD panel davduck53 Troubleshooting and Beginner Help 3 03-05-2010 10:19 AM
How do you clean your NEC LCD panel? kurki Digital Processing, Software, and Printing 2 02-06-2010 05:05 AM
Flat Panel Flashes RC Pilot Flashes, Lighting, and Studio 1 10-12-2009 05:51 PM
Permanent ISO display on LCD-panel w/ K10D ? Peter_CH Pentax DSLR Discussion 4 04-22-2008 09:38 AM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
