Originally posted by Wheatfield I'd still like to know how you are getting a raw format off the green mode.
With the K-5, when you pull the most recent JPG picture up for review, the RAW file is actually still in the buffer. You can retrieve it by pressing the AE-L button. This saves it to your memory card. I do this on occasion when I want to PP a picture. It saves space on the memory card by doing this only after you've viewed a JPG and then deciding that you want a RAW file on a specific picture. Unfortunately, Pentax has chosen to save only in the PEF-format RAW file when a pic is taken in the green mode. As I DO use the green mode on occasion for all the reasons I discussed, I find the PEF format annoying, as Adobe Elements 7 will only recognize the DNG format RAW files. A caution is that if you turn your camera off after making a shot, the RAW file in the buffer will be lost and then cannot be saved to your memory card.
The two solutions are to use Adobe RAW converter to convert the PEF format to DNG, or use the Program mode (very similar to the green mode) if you specify the DNG format as the default for all modes other than green. The way I have Program mode set up, it is useful only in daylight; the Green mode allows the camera to take everything into account quickly and get a picture fast in any light when needed. I'm just annoyed that I have to deal with a PEF-format RAW file in this circumstance.
John
