Closed Thread
02-12-2011, 04:52 PM   #541
falconeye's Avatar
Regarding the distance to the target, doesn't it ultimately depend on which kind of situation (close focusing, infinity, general use) you want the best focus/compromise? I understand it is not always possible to get a setting that works best for all distances so my advice would not be to take a generic distance but think about in which situations focus would be most critical for one personally and than use a corresponding distance during adjustment. It may mean that one arrives at a setting that won't be useful/optimal for general use, though.
You are right, again
My comment is meant in a situation where distance is chosen pragmatically: close enough to obtain an uncluttered center. In many cases, that's closer than the important use case. 30x was just a hint when no other distance is obviously better.
With respect to other questions: I'll answer them when the paper goes online.
02-13-2011, 08:53 AM   #542
OK all, just another bad news : I've just found out that under pure fluorescent lighting (fluo strips), my k5 severly back-focuses...
I had to apply a +7 AF correction to get proper focusing...
02-13-2011, 10:12 AM   #543
QuoteOriginally posted by dlacouture Quote
Let the hysterical piling on and 100 threads of complaints begin!
02-13-2011, 05:37 PM   #544
GregK8's Avatar
OK, I have been now trying for two days to try and test this, and all I have found is that when the DOF for a particular lens is a centimeter, there is margin for error in the process.
If the AF has to focus the lens on a closer target, I tend to get back focus, if t has to focus on a target further away than it's current setting, it tends to front focus, but not all the time. If I let the camera pick the focus spot, it always front focuses, if I use the center sensor only, I get the variability in results. Sometimes it is spot on, so all I seem to be able to determine is that there is some variability in the AF system, and if we are talking about a 1cm DoF, then we are probably talking microns in terms of the change in position of the lens wrt the target.
Is it possible that this is all within the spec of the K-5 as a "Prosumer" camera (as opposed to a "Pro" camera)? Are we just asking too much?
02-13-2011, 05:57 PM - 1 Like   #545
Banned
QuoteOriginally posted by GregK8 Quote
Yep, I'm asking too much for a camera to AF correctly and come without globs of glue on the sensor. But what the hell, what's $1,500 amongst Pentax and its loyal customers.
02-13-2011, 06:19 PM - 2 Likes   #546
QuoteOriginally posted by donallison13 Quote
As always, your contribution to technical issues is well-reasoned and brilliantly argued.
02-13-2011, 07:48 PM   #547
Smeggypants's Avatar
What is disturbing is that you are asking these questions based upon your experience with YOUR copy of the K-5.
With respect you should think to allow for the fact that maybe the low light FF fault may not be equal or even present in every copy.
My K-5 has a low light FF problem. It's consistently reproducible. My K20D and K10D have no such problems in the same level of light
02-13-2011, 07:58 PM   #548
Class A's Avatar
I don't think it is too much to ask for that the current flagship models does not show 6cm front focus (folder image post by Blende8) in a situation that the K20D masters.
02-13-2011, 08:24 PM   #549
GregK8's Avatar
Well, I am going to just chalk my experience up to saying I guess my individual camera does not have this problem, and then politely excuse myself from the discussion so as not to feed the animosity.
I do believe that there are people that experience this problem, I am not trying to say it is imagination, just that I personally cannot recreate it in a repeatable and predictable way.
02-13-2011, 10:35 PM   #550
Class A's Avatar
Falconeye might be interested in your measurements, just like he's interested in Christine Tham's measurements. Maybe you can help by not leaving the thread?
02-14-2011, 01:31 PM   #551
MCR
Well, I try K-5 with my lens too. In my opinion all is OK:
DAYLIGHT:
1. K-5 FA77 daylight
2. K-5 FA43 daylight
3. K-5 DA*50-135 daylight (at 135)
4. K-5 DA*200
5. K-5 DA*16-50 daylight (at 50)
INCANDESCENT LIGHT (some photos, all OK)
1. K-5 FA77 night
2. K-5 DA50-135 night (at 135)
CANDLE LIGHT
1. K-5 FA77 Candle
2. DA*50-135 Candle (at 135)
02-14-2011, 01:44 PM   #552
QuoteOriginally posted by MCR Quote
Maybe it is, maybe not. The EXIF data seems to be stripped so there's no way to tell what light level (EV) any of these were shot at.
Of course, if you're happy, that's all that really matters.
02-14-2011, 02:08 PM   #553
QuoteOriginally posted by areidjr Quote
Check out my post #458 where I describe a quick test that will show you in about 5 minutes whether you have the FF issue or not.
I am interested in your results...
02-14-2011, 02:25 PM   #554
MCR
Exifs was stripped by flickr in smaller size; original size has exif : AF-k5-test - a set on Flickr
No "maybe is" - all is ok (not only in chart tests).
02-14-2011, 02:36 PM   #555
So have Pentax silently fixed the problem in newer cameras, or is it a random thing and sometimes a good camera pops out?
Closed Thread
camera, dslr, issue, k-5, k-5 ii, k-5 iis, k5, pentax k-5, re, thread
Help! K7 malfunctioning samski_1 Pentax DSLR Discussion 9 07-11-2010 03:24 PM
Probably not relevant or welcome here climbertrev Non-Pentax Cameras: Canon, Nikon, etc. 4 05-24-2010 05:15 AM
camera based sensorcleaning how relevant is it. hein Pentax DSLR Discussion 13 09-13-2009 12:26 PM
Light fluff but news.. sort of jeffkrol Pentax News and Rumors 8 12-30-2008 06:30 PM
Snowflakes... ( artificial ) TrailSeeker Post Your Photos! 0 12-12-2006 08:33 AM
All times are GMT -7. The time now is 05:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
