You should have started seperate thread in the Flash forum, but anyway.
Have you checked if all of the flashes are firing? If they are, then it sounds like your flashes are not as powerful as you expect them to be.
You might have to move them closer to the subject, get more power, increase iso or open up the aperture.
Originally posted by stevelink Season's Greetings!
I have a new Metz 50 AF-1, and I am getting some unexpected underexposure using the following set-up:
On the Pentax K-5:
Lens: Pentax DA 16-45 at 19mm (Approx. 10 ft. from group)
Flash in Wireless Mode: Off
Camera in Manual Mode: 1/125 sec at f/9 ISO 200
Built-in Flash Mode: ON at -0.7 in Control Mode
Quality: RAW + JPEG Fine
Umbrella Flashes:
Metz Mecablitz 50 AF-1 at Full Power Servo Mode (Power = 1/1) into a 44” white umbrella approx. 5 ft. from subject at camera right (Main light)
Sunpak Auto 323 Super at ISO 200 Manual Full Power into a 40” white umbrella approx. 6 ft. from subject at camera left (Fill)
The resulting image looked at least a half stop under-exposed (both on K-5's LCD and my computer display in Photoshop prior to correction) However, I did not want to either open the aperture (sacrificing some needed DOF) or increase the ISO, and I could not really move the umbrellas any closer, or they would have intruded into the image. (I suppose a vertical composition was possible, but that obviously would not have affected the exposure.)
Any thoughts on how I could have improved the image would be greatly appreciated! I'm thinking I may not have the K-5 settings for camera/flash sync configured correctly. Thank you.
