I've done my test under Halogen lights, using a dimmer switch to alter the EV for subsequent shots ...I see FF at EV 4 under these conditions...its minor, but there none the less
thanks to Jolepp for supplying the test sheet, rep added
shot parameters were , shake reduction off, tripod mounted with remote release, ISO 100......subject was 500mm from the Focal plane , WB AUto
at EV 2 the af lamp assist came on, so I disabled it
I did a sequence of three shots
1 View Finder Phase detect
2 View finder phase detect with Mirror lock up
3 Live view
the MLU shot showed no difference, so I will not show those in the post..
EV of the tests were 2,3,4,5
lastly I tested EV4 { were for me FF was present at F2.8} at F4....
the dof was razor thin....10mm at F4 it went to 14mm
the second shot in each sequence if LV for reference
EV2
EV3
EV4
EV5
EV4 @ F4
