01-20-2011, 01:39 PM   #1
Jimfear's Avatar
Can't use flash on rear curtain?
Hi, I'm having a problem. I can't select either flash on rear curtain or wireless flash, not in any mode. I tried going through the menus to see if I find anything that would conflict with it but I didn't.
Am I missing something here? Firmware 1.02 in camera.
01-20-2011, 01:41 PM   #2
enoeske's Avatar
what flash are you using?
01-20-2011, 01:46 PM   #3
Just as important, What lens are you using? What Mode are you using on your camera? Pentax disables those features with M type lenses and in some of the Auto shooting modes as well (like Green Mode).
Trailing curtain Does work on the K5 (external flash)
https://www.pentaxforums.com/forums/members/jeffjs-albums-12-days-christmas-p...them-toys.html
01-22-2011, 01:31 AM   #4
Jimfear's Avatar
QuoteOriginally posted by enoeske Quote
The K-5s own flash.
QuoteOriginally posted by JeffJS Quote
K5JS1960 mDA1224f4 12days Dec18 1small I don't know how many different ways I can preset my 2 foot tall Christmas tree but I'm sure I'll find another before the end of the game. In the meantime, another train shot from me. Done with a trailing curtai
Using K series manual lenses i M mode. I've checked the manual (page 184) where it said that trailing flash doesn't work in green mode, X and movie mode. All other should work.
01-22-2011, 04:02 AM   #5
QuoteOriginally posted by Jimfear Quote
The K-5s own flash.
As far as the camera is concerned, K series = M series.
01-22-2011, 10:06 AM   #6
enoeske's Avatar
without the electrical contacts in the lens to tell the camera about the aperture and focal length, the flash cannot use ttl data to automatically adjust the power. Therefore, with K or M lenses, the pop up flash just blasts at full power at front curtain. Not sure what you were expecting with respect to wireless if you are only using the pop up...
01-24-2011, 06:27 AM   #7
Jimfear's Avatar
Ah sorry, I was in a hurry when I read your last post and didn't catch that "as well" part. Thought it was the the combination of manual lenses and those modes.
But adjusting the power of the flash automatically is in my opinion irrelevant to it firing at the rear curtain. The power can be set manually right? Or is the +/- just some adjustment of an automatic value? Anyway, if it cannot use ttl and thus fires at full power, why should it not be possible to fire at full power at the rear curtain? If it is only the lack of electrical connections then this is a firmware problem that can, but probably won't, be fixed in future firmware updates. It's just a matter of when the flash should fire, not if it fires at the right level.
Regarding the wireless mode, I am very aware that the pop-up flash is situated on top of the camera and that the two are actually physically connected. But I ask because I cannot select wireless mode, regardless of the flash I would be using.
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Rear curtain and slow shutter speed flash sync question for the 645D Warped Pentax Medium Format 9 01-28-2011 11:36 AM
Rear curtain sync mindglow Troubleshooting and Beginner Help 8 12-28-2009 10:42 AM
SB-24 Rear Curtain on K2000 Nomadic Zen Pentax Camera and Field Accessories 1 12-11-2009 07:30 PM
option for rear curtain sync on k100d with on-board flash??? eclipsed450 Troubleshooting and Beginner Help 2 03-04-2009 10:16 AM
Does my K200D have rear/trailing curtain flash sync? K200D Pentax DSLR Discussion 2 07-29-2008 06:32 PM
All times are GMT -7. The time now is 05:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
