02-02-2011, 06:28 AM   #16
For whatever this comment may be worth at such a late stage in the posts, I have found K5s to be a bit over-sensitive to colour temperature shifts simply through slight change of camera position. This is noticable in comparison with the K7.
Generally my solution is to either set a custom white balance using a Whibal (white balance reference card) or, more simply, include a picture of the Whibal one or more shots and use that as a white balance reference when I import the files into Adobe Camera Raw. The custom white balance would probably suit jpeg shooters better. I always use DNG.
02-02-2011, 11:24 AM   #17
Yes, I've been able to recreate the same problem under fluorescent lights at higher shutter speeds
The K-5 is the pretty much the first camera I've had which can be used for no-flash shots indoors at high shutter speeds, thanks to its excellent high-ISO capability.
This is an unusual case where one of the K-5's significant strengths causes an unintended photography problem under special conditions.
02-03-2011, 07:12 AM   #18
strobist blog says this is normal at faster than 1/60th
camera, color, color temperature, dslr, image, k-5, k-5 ii, k-5 iis, k5, lenses, pentax k-5
LX Focus Woes. tendim Pentax Film SLR Discussion 1 12-05-2009 07:52 PM
Color Temperature in Pentax DSLRs BB_Zone28 Pentax DSLR Discussion 35 11-13-2009 11:04 AM
Color temperature with gray card senojobmij Pentax DSLR Discussion 12 06-16-2009 09:25 PM
K20D AF woes NicholasN Pentax DSLR Discussion 18 06-11-2008 10:27 PM
Get that monitor off of the default color temperature! slip Digital Processing, Software, and Printing 16 11-30-2006 06:51 PM
All times are GMT -7. The time now is 08:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
