Originally posted by JeffJS Just make sure you have your control flash set for HSS. With this combo, line of sight rules still apply. That is the reason for my original statement about radio triggers being better for some applications. That line of sight doesn't necessarily have to be direct, all that is required is that the slave flash sees the signal.
Thanks again. It worked well. A friend told me it wouldn't work and when I had tried it before I don't believe I had the control in HSS. I am now smarter.
But since you are in the know, am I correct that you have to have an external flash on the hot shoe acting as a controller (the built in won't work), right?
And the Metz won't work as a "dumb" (non-P-TTL) slave flash, right?
