02-12-2011, 11:02 AM   #1
K-5 with old SMC-M lenses
Hello,
I am new here, but I used to read many important threads posted on this site. I'd think my question could be primitive (or may be a stupid question), but please help me .
I recently bought a K-5 with a DA 18-135mm lens. All works fine. I have then tried to use old SMC-M lenses for my K-5. However, my K-5 won't take photo with SMC-M lenses (whenever the SMC-M lens is mounted on the K-5, its shutter does NOT work). I guess there could be some sort of setting(s) that I don't know.
Does anybody know how to take photos with the old SMC-M lens mounted on K-5?
Thank you.
02-12-2011, 11:07 AM   #2
bobell69's Avatar
You must use the camera in manual in order to make it work with the M lens. Set your autofocus to Manual as well as the set the top dial to Manual. Set the aperture to your desired f stop and then press the green button which will set the shutter speed. Press the shutter and it should work.
02-12-2011, 11:26 AM   #3
Hello,
Thank you for the answer. I actually have set the 'AF-S' to 'MF' as well as the top dial into the position of M (manual). However, whenever the K-5 is mounted with the M lens, the symbol for "F' is blinking (shown as 'F --'; thus no Aperture value)', and the camera does not take any photos. I have tried the green bottom as well. I guess, there could be a problem for setting "Aperture". Also, when the modes are in 'MF' and 'M', I am not able to control ISO, which is frustrating.
02-12-2011, 11:35 AM   #4
You need to go into the custom menu and set "use aperture ring" to "permitted" I don't own the K-5 so I don't know exactly where in the custom menu it is. Check your manual.
NaCl(it's in there somewhere)H2O
02-12-2011, 11:44 AM   #5
Dear sodium cloride in dihydrogen oxide and bobell69,
I got it (it is under "C 27: Using aperture ring Reset Custom Functions). All works fine.
Thank you very much.
02-12-2011, 11:48 AM   #6
LeFanch's Avatar
Hi!
The item [27. Using Aperture ring] must be set to [Allowed] in the [C Custom setting 4] menu.
I hope that helps!
LeFanch
Edit: Way too slow! ;-)
02-12-2011, 01:58 PM   #7
kiwi_jono's Avatar
Really wish they would enable it by default -would save so many questions.
No idea why they don't.
02-12-2011, 02:21 PM   #8
Doesn't the additional step slow the camera down? That may be valid reason. No one uses M lenses anyway. Only me and few others. :-)
02-12-2011, 03:57 PM   #9
bobell69's Avatar
QuoteOriginally posted by elho_cid Quote
I agree no one uses them anymore.......Guess I had better stop using mine too.
02-12-2011, 07:51 PM   #10
Dear LeFanch,
Thank you anyway. A lot of things to know to use this cool K-5...
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lens, lenses, pentax k-5, question, smc-m
Pentax Km and old manual lenses: SMC Takumars & Tamron Adaptall 2 lenses Kendrick Troubleshooting and Beginner Help 10 04-14-2010 03:23 AM
SMC vs non-SMC versions of Lenses dosdan Pentax SLR Lens Discussion 2 08-16-2009 05:02 AM
smc f and smc fa lenses on k100d wombat62 Troubleshooting and Beginner Help 4 04-04-2009 11:11 AM
For Sale - Sold: 3 Lenses: SMC M50/2 - SMC M28/2.8 - Vivitar M42 400/5.6 IF Buddha Jones Sold Items 8 05-27-2008 05:40 AM
For Sale - Sold: M42 Lenses - SMC 50mm F1.4 | SMC 135mm | 135mm barbosas Sold Items 8 02-17-2008 11:49 AM
All times are GMT -7. The time now is 09:38 AM. | See also: NikonForums.com, part of our network of photo forums!
