02-17-2011, 03:02 PM   #1
Newbie questions: Langauge Screen and not saving preferences
Hi everyone,
I just received my k-5. I am very happy with it!!!
One question though. Why does the Language selection screen always come up when i turn on the camera? Either that or the "Initial Setting" screen appears every time! Is there any way to turn it off? It's annoying me!
Also, when I first started using the camera, I changed a few settings (e.g. NTSC to PAL. Every time I turned off the camera, the settings would revert! But there were other settings which would stay! Then, after a while, even the NTSC/PAL setting would stay after power off. Is there some sort of internal battery or supercap that has to charge properly before some settings are remembered? I know about the "Memory" menu, where you choose what will be saved when the camera is powered off, but i don't think the NTSC/PAL setting comes under any of those!
02-17-2011, 05:34 PM - 1 Like   #2
Ole
Ole's Avatar
Make sure you set the date, time, location and language and actually save the information. That should take care of your problem. If you just exit (without saving) the initial setup menu it will reappear.
02-17-2011, 05:41 PM   #3
Ah! Thanks for that! I failed to click "ok" on the "Settings Complete" bar. Instead I was just exiting the menu with the menu button! Sorted now thought!
02-17-2011, 08:15 PM   #4
creampuff's Avatar
I think you should read and slowly digest the operating manual first.
02-17-2011, 09:04 PM   #5
I have read the operating manual twice now. Once before I bought the camera and once after.
I just didn't realise it didn't save the settings on that particular screen without a special selection of a special button. Most of the other settings one changes in the camera are saved without this additional step.
Thanks though.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, screen, settings, time
K-x newbie questions hray Troubleshooting and Beginner Help 10 02-10-2011 03:52 PM
Newbie Questions on K-r vegasmike Pentax K-r 2 01-06-2011 07:38 PM
Newbie questions about saving RAW files lectrolink Digital Processing, Software, and Printing 7 08-03-2010 12:08 AM
A Hello and few Newbie Questions jnash4 Troubleshooting and Beginner Help 7 07-01-2010 12:53 PM
newbie from AZ, saving for a K110D Brianna Welcomes and Introductions 5 07-25-2007 08:15 AM
All times are GMT -7. The time now is 01:22 PM. | See also: NikonForums.com, part of our network of photo forums!
