02-18-2011, 02:12 AM   #1
Pentax K5 Battery Issue
Hey Folks,
I few days ago I upgraded from my K20 to the K5. I've never had an issue with the K20 and have been a loyal pentaxian. Even though I have charged my factory battery for 10s of hours whenever I put it in and turn the camera on it will show a full battery. Then I will attempt to autofocus, and before I can even press the shutter down the battery shows zero and the camera turns off. On other occasions, it has taken a picture in manual mode but only black shows up. I'm using a DA* lens with the camera so I dont think it will be a compatibility issue. Does this sound like a straight battery issue or is there something I am missing that could be an easy fix.
Thanks for all your help.
02-18-2011, 03:51 AM   #2
Moderator Emeritus
Sounds like you got a bad battery. It happens sometimes. Maybe the charger is defective and not actually charging the battery correctly. If the camera is very new, I'd contact the retailer and return the entire unit. There is a possibility that the camera has a problem and this could take 1,2 or 3 parts returns if you send back one peice at a time.
02-18-2011, 10:11 PM   #3
SpecialK's Avatar
Generic batteries cost about $15. I would start there.
Scratch that, I'd see if they would send a battery and charger. If not, return it all.
02-18-2011, 10:46 PM   #4
I would exchange the entire outfit for another one. Then get a couple generic spares and a wall hung charger.
battery, camera, dslr, issue, k-5, k-5 ii, k-5 iis, k20, k5, pentax k-5, pentax k5 battery
K-x Battery Issue gkamieneski Pentax DSLR Discussion 6 12-17-2010 02:51 PM
K-7 Battery Grip issue penties rider Troubleshooting and Beginner Help 29 03-27-2010 01:26 AM
Battery issue with K-x switters Pentax DSLR Discussion 15 02-26-2010 09:06 AM
Battery compartment issue john_ven24 Troubleshooting and Beginner Help 8 01-31-2009 07:41 AM
K100D battery issue Pierrot Pentax DSLR Discussion 22 04-04-2007 10:04 AM
All times are GMT -7. The time now is 08:00 PM. | See also: NikonForums.com, part of our network of photo forums!
