03-02-2011, 07:01 PM   #16
MrPetkus's Avatar
Wiping all AF adjustment settings to factory default has resulted in a noticeable improvement.
Edit: Reset C4 - "Reset Custom Functions".
03-02-2011, 07:11 PM   #17
dgaies's Avatar
FWIW, no difference on my K-5 whether the AF adjustment is on and set to zero or whether it's been freshly reset.
03-02-2011, 08:47 PM   #18
MrPetkus's Avatar
Noticeable improvement in some circumstances != FF fix. I consider the cure claim bogus. That said, it's probably wise to reset one's camera before a firmware update. It's likely firmware releases are predominantly tested in default states.
03-02-2011, 10:42 PM   #19
Perhaps everyone posting who has tried this could also state what firmware they have> Thought it may be relevant if they are different.
03-03-2011, 08:52 AM   #20
There are 3 "resets" :
- C.26 (AF micro adjustements only)
- the one after C.27 (Custom settings only)
- the one at the bottom of the "Tools" menu, tab 3. I guess it resets everything, including all of the above.
I tried all of them and have not seen any improvement.
Firmware 1.02, but I can't remember which sub-version (first 1.02 posted or "silent" one.)
Edit: just in case it matters, I didn't have any AF adjustment before the resets, as my lenses where spot on in daylight.
03-03-2011, 02:11 PM   #21
maciek_w's Avatar
If sometimes my camera fails to focus in several attempts in normally lit room (artificial lighting after dark that is) and even the green lamp doesn't help - would that be a reason for concern?
03-03-2011, 02:33 PM   #22
Deimos's Avatar
QuoteOriginally posted by maciek_w Quote
It depends on how well lit "normal" is. From what I understand what appears as fairly bright indoor light to our eyes can be pretty challenging for a camera, i think the threshold at which our Pentaxs start having issues is below 4 EV? (I have no idea what that actually corresponds to in terms of a light source) But if it really was quite a bright room there could be an issue.
03-03-2011, 02:48 PM   #23
maciek_w's Avatar
OK, this was not a very well lit room. Rather dim. In that case I'm less concerned.
camera, dslr, factory, ff, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 1438 8 Hours Ago 02:13 PM
Suggestion All K5 "stain" issues should be posted in ONE thread. jpzk Site Suggestions and Help 8 03-22-2011 08:57 PM
US "best looking horse in the glue factory" jeffkrol General Talk 5 11-22-2010 07:00 AM
Bad Day at the Factory: A "HLILAND PENTAX" H3 macTak Pentax Film SLR Discussion 6 07-04-2010 05:41 AM
Any known issues with the firmware "reverting" on the K10D? JamieP Pentax DSLR Discussion 5 02-12-2009 01:28 PM
All times are GMT -7. The time now is 11:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
