Closed Thread
03-09-2011, 08:26 PM   #46
LeeRunge's Avatar
Just in time. My k5 is scheduled for delivery tomorrow. Seems the two main issues are resolved. Now we can begin the autorotation complaint storm.
03-09-2011, 08:27 PM   #47
MrPetkus's Avatar
This is a legitimate problem but I think, as you suggest, perhaps there are less regular flash shooters. Who knows. I've forgone PTTL on the K5 and set flash parameters manually with the AF540gz. Given the K5's high DR, I frequently set power output between 1/16 - 1/64, keep ISO @100 (even if it means under-exposing) and raise exposure in PP. My flash fires away all night without a battery change. Perhaps this isn't the most modern way to use a $1400 camera and $400 flash in 2011 but the results are great.
QuoteOriginally posted by efkelly Quote
Too bad the bounce flash overexposure issue still exists. As an event/wedding photographer it kind of stinks. I wonder why this does not get the same amount of attention as the sensor stain or FF issues (maybe not a lot of pentax shooters use flash?). I have had 4 bodies that exhibit all the same behavior. For the people who aren't aware of the problem, set your camera on Manual, f4-5.6, 1/50th second, and any ISO (as long as the scene is not over exposed to begin with. For example, indoors at an event, I will typically shoot at f4-5.6,1/50 sec, and ISO 800 (to conserve flash battery power- at a higher ISO the flash will not have to work as hard)) and try using any flash bounced off the ceiling and compare it to direct (IN PTTL). The flash will overexpose by about a stop or more every time. The only way I have found to control it is to put the camera's highlight expansion on and to dial down the flash exposure -1/3 or -1/5. This is not a permanent solution because when I need direct flash, I have to fumble around to dial the flash up again. When I get some more time, I will post some comparison shots.
Eric
03-09-2011, 08:34 PM   #48
Banned
Congratulations. Enjoy your K5!! It was a camera who deserved it! I must admit that I didn't believe they will be able to solve the issue. Good job! But I'm waiting the Kr firmware fix...
03-09-2011, 08:36 PM   #49
Smeggypants's Avatar
Hmmm - K-5 still not as good as K20D
Ok, been doing a lot of tests ... I will say there is some improvement, but the AF performance on my K-5 is still way behind the K20D. I'll post pictures tomorrow sometimes as it's 3:30an here, but here's the test I just did ....
K20D - Sigma 30/1.4 - exposure f1.4 1/60s ISO160 [apox EV6.5] tungsten light.
AF test chart focus spot on!
K-5 - Sigma 30/1.4 - exposure f1.4 1/60s ISO160 [apox EV6.5] tungsten light.
proves the above the two cameras perform equally well with the same lens and same settings at EV6.5
now taking the light down to EV2 ...
K20D - Sigma 30/1.4 - exposure f1.4 1/60s ISO3200 [approx EV2]
object in room - AF spot on
K-5 - Sigma 30/1.4 - exposure f1.4 1/60s ISO3200 [approx EV2]
object in room - phase AF way front focusses. contrast AF nails it.
Current conclusion: My K20D focus works perfectly at EV2 in all situations i've tried. the K-5 AF has worked in some situations at EV2 but there's many situations including the test above where it has failed miserably.
A lot more testing required.
03-09-2011, 08:37 PM   #50
Great Suggestion MrPetkus. I will give it a try. Sounds a bit easier. I may just upgrade to the 58 AF2 and use the A mode...
03-09-2011, 08:41 PM   #51
Wow!
QuoteOriginally posted by areidjr Quote
I never was able to reproduce that fault with the 3 copies of the K-5 that I had, all of which suffered from severe FF. When I get another K-5 I'll test it using your settings. I shoot a lot with bounce flash and also with large bounce cards.
I can't believe you can't reproduce the problem. I've done it on every K5 I've touched. Just be indoors with a Negative EV (-1 to -3 or whatever), set the camera on Manual, f4, 1/50th second, and any ISO. Then bounce the flash and you will see. I've seen it on any ISO from 100 to 800 (I rarely go beyond ISO 800).
03-09-2011, 08:43 PM   #52
Yes I am very glad Get 1.02 outa here! My k5 was not happy on 1.02 its auto focus was terrible and at one stage had to reset the camera because it was having freak outs! It kept changing the metering mode and changing from auto focus to manual with out me touching a button well on the screen that is but still !!! Hopefully 1.03 is much more kind
03-09-2011, 08:53 PM   #53
Installed successfully. I never bothered looking into the issue on my own, but I'm glad they are willing to improve the camera's focus accuracy.
03-09-2011, 09:50 PM   #54
Ash
Community Manager
Ash's Avatar
Great news - and I must say it was pretty quickly sorted out.
03-09-2011, 10:07 PM   #55
JayBee's Avatar
Actually, very little improvement, if any.
Thoughts?
All shots DA 40mm f2.8 ISO 80. 3 sec, with 2-sec delay.
03-09-2011, 10:14 PM   #56
alexeyga's Avatar
QuoteOriginally posted by JayBee Quote
Thoughts?
What were you focusing on?
03-09-2011, 10:18 PM   #57
Does not look like an improvement to me, according to the posted images. Smeggypants is also not convinced. How about a default reset or reset of the AF fine adjustment parameters?
03-09-2011, 10:18 PM   #58
QuoteOriginally posted by alexeyga Quote
I would say the green leaves.
03-09-2011, 11:47 PM   #59
A Request
QuoteOriginally posted by Smeggypants Quote
Smeggy,
A request:
My K20 will not hold DOF in low light (EV2) at f1.4 (FA 50) and probably not at 2.0 either. It is close at 2.8 and in at f4, no trouble at f5.6.
If the K5 would do at least as well as that, it would be ok for most indoor shots I would be shooting (well, except for the bounce issue).
Can you shoot a comparison or test at f4 EV 2 or so?
If that looks ok, I will probably re-order the K5 as it will work about as well as my K20 does.
I must say that the Contrast and PDAF shots in this thread are not at all encouraging, as they look just like the results I saw with my earlier K5 bodies.
Thanks,
Ray
03-09-2011, 11:56 PM   #60
Banned
Thoughts?
Did you used tungsten light? Or it's in low daylight?
Did you RESET camera after the update?
Closed Thread
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Pentax Firmware Hack site tr13 Pentax DSLR Discussion 433 09-30-2014 08:59 AM
Firmware differences between US and Japan? bwDraco Troubleshooting and Beginner Help 1 11-18-2010 08:08 PM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
Photo samples from K-7 Official Site Japan vizjerei Pentax DSLR Discussion 6 06-06-2009 09:26 PM
All times are GMT -7. The time now is 08:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
