Closed Thread
03-10-2011, 12:09 AM   #61
now we just need tethering!
But that's in a different category of firmware updates (fixes versus new features)
03-10-2011, 12:21 AM   #62
QuoteOriginally posted by DogLover Quote
Did anybody else notice that this firmware loaded waaay faster than 1.02? I just did 1.02 about 48 hrs. ago when I got the camera. Perhaps not much code was required to fix this.
It's a full firmware, not a patch. If it was a patch people not on 1.02 would have to load that first. So, there's no logical reason for it to load faster as the size is probably similar.
03-10-2011, 12:32 AM   #63
explosive's Avatar
Hurrah. Did someone tell Pentax its my birthday today... \o/
Yippee, now to quickly test...
03-10-2011, 12:34 AM   #64
Col
Col's Avatar
Yes Campdog
I wish they would add to the instructions that when install is done it will say "Complete" on the screen AND the write LED will start flashing.
Switch off, take the SD card out you're done (now delete the file from the card before you try using it for images again).
03-10-2011, 01:37 AM   #65
Firstly the FF was not a big deal. Secondly I knew it was going to get fixed. And third - it did get fixed.
What else?
Ah, yes, this was practically the only problem with the K5, so... stop complaining and start shooting!!!
Thanks to all Pentax engineers for the attitude!
03-10-2011, 02:00 AM   #66
quick test seems to have solved the issue.
03-10-2011, 02:19 AM   #67
Class A's Avatar
QuoteOriginally posted by Smeggypants Quote
My K20D focus works perfectly at EV2 in all situations i've tried. the K-5 AF has worked in some situations at EV2 but there's many situations including the test above where it has failed miserably.
What puzzles me slightly about your results is that the K20D is not supposed to do well in Tungsten light. That's why Pentax introduced the colorimetric sensor with the K-7. I wonder how the K20D can outperform the K-5 in all sorts of lighting conditions. In some, maybe, but it shouldn't be able to do it in all of them.
03-10-2011, 02:25 AM   #68
QuoteOriginally posted by Col Quote
you dont need to do that
03-10-2011, 02:44 AM   #69
The AF lamp is now broken in 1.03 it does not come on no matter what conditions...
edit: Okay i fixed it, you have to turn OFF the AF assist lamp in the menu, attempt a shot, then turn the AF assist lamp back ON and it starts working again!
menu: c / 3 /17
Interesting! the camera was focusing just fine in a lot of conditions it now considers need the AF lamp.
03-10-2011, 03:47 AM   #70
QuoteOriginally posted by WerTicus Quote
menu: c / 3 /17
Judging from some posts in this thread, I think it is probably a good idea to reset the camera to factory settings after installing 1.03.
03-10-2011, 03:58 AM   #71
Banned
Can you make some/more tests with this 1.0.3 firmware, please? It really improve the ff issue or Pentax just scores at the artistic impression?
03-10-2011, 04:45 AM   #72
Fer
QuoteOriginally posted by dreamfoto Quote
Sure, no big deal. ALL my photos in tungsten light are front- focused, but I guess that's unimportant.
I'm keeping my fingers crossed that this firmware will fix it.
03-10-2011, 04:52 AM   #73
QuoteOriginally posted by efkelly Quote
Too bad the bounce flash overexposure issue still exists. As an event/wedding photographer it kind of stinks. I wonder why this does not get the same amount of attention as the sensor stain or FF issues (maybe not a lot of pentax shooters use flash?). I have had 4 bodies that exhibit all the same behavior. For the people who aren't aware of the problem, set your camera on Manual, f4-5.6, 1/50th second, and any ISO (as long as the scene is not over exposed to begin with. For example, indoors at an event, I will typically shoot at f4-5.6,1/50 sec, and ISO 800 (to conserve flash battery power- at a higher ISO the flash will not have to work as hard)) and try using any flash bounced off the ceiling and compare it to direct (IN PTTL). The flash will overexpose by about a stop or more every time. The only way I have found to control it is to put the camera's highlight expansion on and to dial down the flash exposure -1/3 or -1/5. This is not a permanent solution because when I need direct flash, I have to fumble around to dial the flash up again. When I get some more time, I will post some comparison shots.
Eric
Eric
I do not know what type of flash you are using, but I have a hunch it may have more to do with you flash unit than the camera. I am using the Metz 58 AF-1 with the K-5 and I had a bit of a problem with it similar to yours. However since updating the Metz FW to Ver. 3.0 all problems I previously experienced are gone.
Just for interest I replicated some shots with your above mentioned settings and everything seems perfect to me. My K-5 and the Metz are now a happily married couple.
Greetings from sunny Melbourne
03-10-2011, 05:26 AM   #74
Okay, I've ran some quick tests, and from what I saw, the problem is solved for me...
Using my FA50/1.4, the camera now focuses quickly and accurately, without Assist lamp, right down to EV -0.12 (1/60, f/1.4, 12800 iso), whereas before it failed to do so at a mere EV2-3!!!
Moreover, it was on a face without any direct light (no specular reflections), so lots of red-ish light, low contrast.
Below that (and still without the AF assist lamp), and you can see a slight drift toward FF... But it's at such ridiculous light levels (going into 51200 and low speed territory here) that I had trouble finding the target, so...
Will do some more tests tonight , as it's full daylight right now and finding a dark place is not easy!
03-10-2011, 05:44 AM   #75
QuoteOriginally posted by secateurs Quote
The FW already supports tethering. The missing piece is the PC application software.
Closed Thread
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Pentax Firmware Hack site tr13 Pentax DSLR Discussion 433 09-30-2014 08:59 AM
Firmware differences between US and Japan? bwDraco Troubleshooting and Beginner Help 1 11-18-2010 08:08 PM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
Photo samples from K-7 Official Site Japan vizjerei Pentax DSLR Discussion 6 06-06-2009 09:26 PM
All times are GMT -7. The time now is 12:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
