03-10-2011, 09:17 AM   #1
ISO 80. Where is it?
Not that I need it badly. But reading so much about it and being with K-5 only few weeks I am testing and learning my camera.
So where is the ISO 80. All I can see and access is ISO 100. Also manual does not say a word about ISO 80.
03-10-2011, 09:20 AM   #2
Go to your C menu, option 3. Expanded sensitivity ON. Will enable ISO 80-51200. It's also in the manual.
03-10-2011, 09:54 AM   #3
Yes! All I can get now is ISO 160 most of the modes.
03-10-2011, 09:57 AM   #4
jrforman's Avatar
Go to item 3 on the custom menu - expand sensitivity, select yes.
03-10-2011, 10:44 AM   #5
QuoteOriginally posted by vanakaru Quote
Turn off highlight correction in your D-range settings, otherwise you will only get ISO 160 as a minimum.
03-10-2011, 10:45 AM   #6
MrPetkus's Avatar
Sounds like you have Highlight Correction enabled in the D-Range Setting menu selected.
03-10-2011, 10:53 AM   #7
Great! Thanks for helping!
03-10-2011, 10:54 AM   #8
turn off expanded highlights to get down from 160
03-10-2011, 10:57 AM   #9
Rupert's Avatar
Sort of scary...I have had my K20D for almost three years and I am just now on page 12 of the manual....this might be a problem for me, you think? I may be here a lot asking questions, I was raised believing that real men don't need instructions or maps....any of you like that?
Best Regards!
03-10-2011, 10:59 AM   #10
What's the consensus on this? Would you rather have ISO 80 available, given plenty of light, of course, or highlight correction enabled?
03-10-2011, 11:51 AM   #11
kyteflyer's Avatar
QuoteOriginally posted by DogLover Quote
I just LOVE low ISO, even in relatively low light, and don't much care about highlight correction I've mostly been shooting at 100-400. Haven't been down to 80 yet.
03-10-2011, 12:04 PM   #12
MrPetkus's Avatar
If there are some real bright highlights in the scene, highlight correction yields ~1 stop extra highlight range by flattening highlights on the tone curve. This has a subtle effect and can minimize clipping. OTOH, going from ISO 80 to 160 reduces overall DR by almost a full stop. So all things being pretty much equal it depends on whether you want to spend time in PP or have the camera do it.
Personally, I often enable highlight correction as a convenience.
03-10-2011, 12:35 PM   #13
QuoteOriginally posted by MrPetkus Quote
I think I'd like to try shooting some sun-bursts with highlight correction enabled just to see what the results would be. Might be un-noticeable, might be un-desirable.
03-10-2011, 12:47 PM   #14
Straight into the sun, @ ISO 80, to give you an idea.
03-10-2011, 12:50 PM   #15
MrPetkus's Avatar
Nice pic
camera, dslr, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Photos: K-5 at ISO 6400 AND ISO 12,800 PeterKBurian Pentax K-5 & K-5 II 2 01-07-2011 07:01 AM
I am getting a lot of noise at ISO 800 and ISO 1600.... Abstract Pentax K-5 & K-5 II 19 11-30-2010 10:48 AM
K-r vs. K-x ISO samples (or return of the ISO flower!) devorama Pentax K-r 31 10-29-2010 02:05 AM
[Auto-ISO] so, is the K5 and Kr brave enough to use max iso? Reportage Pentax K-5 & K-5 II 13 10-24-2010 03:30 PM
Tests iso 200 to iso 3200 with k100d Deni Post Your Photos! 0 06-20-2007 05:17 AM
All times are GMT -7. The time now is 04:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
