03-27-2011, 06:50 PM   #136
Ash
Community Manager
Ash's Avatar
All the best with that Smeggy.
I've been fortunate.
A pre-stain fixed model with no stains (yet).
Didn't have noticeable FF in low light in v1.02
No FF problem in any light and for all focal distances (low white fluoro and tungsten lights included) with v1.03
Hard to know if there was any change with the firmware update - all seems to be in order for me.
03-27-2011, 07:38 PM   #137
Smeggypants's Avatar
Thanks Ash. keeping my fingers crossed
03-28-2011, 01:26 AM   #138
Tommot1965's Avatar
ash
do you have the 16-50 DA ?..if so could you test it at 16mm...my sigma 17-50 still refuses to get a good focus until 35 mm in low light..from 35 mm its fine..any thing under that..not fine
03-28-2011, 05:00 AM   #139
Ash
Community Manager
Ash's Avatar
Sold that one away last year Tommo and decided to keep on with the Tamron 28-75.
You mean to say the Sigma front-focuses on your K-5 in low lighting?
You have the v1.03 firmware I assume...
And this problem persisted despite the update?
I will do a quick and dirty check with my 12-24 and get back to you on that one...
03-28-2011, 05:13 AM   #140
Tommot1965's Avatar
You mean to say the Sigma front-focuses on your K-5 in low lighting? yes, but from 17-35mm only, past that its all good, my 70-200 is fine..seems wider you go, the problem persists, but might very well be the lense .
You have the v1.03 firmware I assume...yes mate
And this problem persisted despite the update? all depends on what your focusing on..but Id say yes to that
I will do a quick and dirty check with my 12-24 and get back to you on that one...onya mate .....nothing too scientific..just a real world does it focus test ..
cheers Ash
as I say it might very well be my 17-50 thats the issue....be nice to see others at that FL having no probs, then I can sort the lens if its that
03-28-2011, 07:13 AM   #141
Just received my replacement K-5. It's a 4xxxxxx serial number built in January this year.
It arrived with V1.01 installed. A quick test shows it's front focussing @ EV2 like my original copy, but perhaps not as much. I'll install 1.03 and do some proper tests after I've woke up a bit.
03-28-2011, 07:48 AM   #142
Ash
Community Manager
Ash's Avatar
Fingers crossed Smeggy.
03-28-2011, 07:50 AM   #143
I'm interested as well since my K5 still FF with wider lenses.
03-28-2011, 08:21 AM   #144
After loading 1.03 the AF at EV2 is much better than my old K-5. In fact sometimes it's spot on.
What is notable though is that the AF is inconsistent with 1.03. Whereas with 1.01 it was FFing consistently at EV2 it now varies between spot on and not as much FF as 1.01.
I also noticed that the AF was a bit inconsistent in daylight too with 1.03. I'm certainly much happier, but I feel pentax need to continue to try and improve the AF performance. Falk's latest tests would confirm this I think.
I'll try and get some proper tests done soon with my new Body. I'm also intending on buying a 2nd K-5 this week so that will be an interesting comparison
03-28-2011, 09:44 AM   #145
tlwyse's Avatar
QuoteOriginally posted by Smeggypants Quote
Hey there Frank.
Yes I agree with your points and I am intending to build a more accurate focus tester with a sensor parallel focussing surface,as well as trhe angled Ff-BF scale. A forum buddy has already sent me a pdf to print out a chart from an I'm going to make an MDF structure in the near future to glue the charts to.
Why not just get the LensAlign?
Seems to have the best of both worlds....flat/parallel focusing target combined with the angled ruler.
Terry
03-28-2011, 12:06 PM   #146
jsherman999's Avatar
End point, this round?
And that just may be as good as it gets with this iteration of the Pentax AF module. It sounds like it shows the same behavior as the Canon 40D, but maybe a bit more consistent than the 40D even.
If you want the best low-light AF on the planet, get the D700 - otherwise, I wonder if the K-5 might actually match most other aps-c-level models out there now.
That's my main concern with Falk's tests - There isn't really much to fault technically, but the big underlying problem with the whole thing is that he does not test the 60D, 7-D, D90, D300, D7000, etc, and it may be that this 'AF problem' isn't really a problem at all when compared to other bodies shooting under the same conditions.
Or it could be a real big problem compared to those other bodies. We just don't know unless we've shot multiple systems with similar lenses in similar situations and can compare somewhat subjectively. I know my D90 spanks my K20D in low-light AF speed and accuracy, I'd really like to know how D90 stands up against the K-5. (I guess I'll just have to buy a k5 to find out, huh? )
03-28-2011, 12:47 PM   #147
Tom S.'s Avatar
QuoteOriginally posted by tlwyse Quote
Terry
$80 - $240? Wow - they certainly are proud of those, aren't they?
03-28-2011, 01:32 PM   #148
Terry
What's the point in paying all that dosh when I can make one for free.
I already have chopsaw, wood and enough carpentry skills
03-28-2011, 01:36 PM   #149
Well who knows how other manufacturers models perform?
I just know my K20D performed much better AF in low light than my previous K-5.
I'm not totally convinced my new K-5 performs as well as my K20D yet, but initial rough tests show that it probably will. I'm going to build a better test bed with a vertical focus target before doing any further tests.
03-28-2011, 02:14 PM - 1 Like   #150
Ash
Community Manager
Ash's Avatar
Smeggy, I still have my K20D and have given it a run alongside the K-5 I have now, and I can say the difference is quite clear. The K-5 is more direct, more sure with locking on focus and is not any less accurate with focusing in low lighting as far as I could tell. So I do wonder whether your previous K-5s had issues.
Tommo (and others interested), I gave my K-5 with v1.03 a low-light run with my DA 12-24 and DA 18-55 at their widest focal lengths, and after about half an hour of 'testing' I finally managed to get my K-5 to front focus! Once.
At about EV1-2 I took about 20 shots with both lenses knowing the exact focus point, and despite trying different AF points, different focus distances, using AF assist lamp or not, out of all these shots I got one from the DA 12-24 front focused by perhaps a couple of centimetres. But I could not get it to replicate the front focusing again. So I gave up.
I accept focusing won't always be perfect under these conditions, but from what I've seen the focusing has been pretty much spot on each time I've challenged it. Any more difficult conditions and I'd be wondering what I want in a photograph of the dull scene before me.
camera, dslr, k-5, k-5 ii, k-5 iis, k20d, k5, lens, light, pentax k-5, sigma, test, tungsten
K20D versus K10D Mapleleaf-Mick Pentax DSLR Discussion 13 12-24-2010 10:58 AM
gx20 versus k20d! kositoes Pentax DSLR Discussion 22 09-25-2009 03:00 PM
Tests to determine if a new K20D is faulty eman Pentax DSLR Discussion 21 07-05-2008 10:30 PM
gx-20 versus k20d anyone? davieFL Photographic Technique 1 06-18-2008 12:23 PM
Some K20D Vs K10D ISO noise tests (100 to 6400) RiceHigh Pentax DSLR Discussion 15 02-25-2008 04:00 PM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
