Originally posted by efkelly I can get the same results with -1 to -1.5 EV, but the difference is when you need direct flash (as in like a wedding reception), you have bump up the EV to compensate which takes too much time at a wedding... Plus for a 1400 camera I shouldn't have to dial down -1.5 to get the correct exposures...
Ah, I get it. I got a little confused because of the difference in exposure between the shots of just the K-5.
I thought you were having trouble getting consistent exposures with all the same settings except ISO. I assume the ISO 100 shot you showed wasn't overexposed because the flash power was being eaten up by the higher ISO.
Yeah, this is a problem if you go back and forth. I assume you know that the ec and fec have the same impact in manual mode - doesn't get rid of the problem but sometimes I find it a little faster to adjust the ec for the flash changes rather than going into the fec.
Or perhaps you could just hire a 6 foot 5 inch assistant with a white shirt and have him stand there on one side as a big bounce source?
