03-15-2011, 12:38 PM   #1
PiotrKrochmal's Avatar
K-5 AF for Manual Lenses support
Hi, I've just got my brand new K-5 as a replacement for stained-one. So I started to setup all function as I had in old one.
So for this topic very interesting is option number 25 in custom menu Catch-in Focus.
When its on You have ability to have AF on manual
Just press deep shutter button and then start to focus manually when camera see it focus it make photo automatically. I had check it with all my manual lenses and its work quite good - sometimes you have to focus gently
Best regards
03-15-2011, 01:00 PM   #2
A word of caution with this- the AF system does have some slight tolerance, so using the AF system for confirmation purposes rather than shooting right away would be a good idea.
03-15-2011, 01:15 PM   #3
QuoteOriginally posted by PiotrKrochmal Quote
Best regards
Even the old K10d could do this.
03-15-2011, 01:45 PM   #4
boriscleto's Avatar
You can even "Focus Bracket" if you put it in Continuous-Hi and turn the focus ring slowly. It will even work with M42 lenses, but for some you may have to short the pins with foil tape.
03-15-2011, 02:10 PM   #5
Jimfear's Avatar
QuoteOriginally posted by boriscleto Quote
And, it doesn't even have the 5 pics limitation the exposure bracket has! How great is that!
03-15-2011, 03:58 PM   #6
nice
af, camera, dslr, focus, k-5, k-5 af, k-5 ii, k-5 iis, k5, lenses, pentax k-5
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
Lack of support for 645 FA lenses!!! kolus Pentax Medium Format 9 09-27-2010 07:04 PM
What B&H Teleconverters will support our lenses? Clinton Ask B&H Photo! 6 06-20-2010 05:02 AM
will K100D support new SDM lenses? axl Pentax DSLR Discussion 6 06-26-2007 01:14 PM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, part of our network of photo forums!
