03-24-2011, 12:04 PM   #1
PhotoMe alternative for Mac
I'd like to know the manufacture date for my K-5 but I'm a mac user... Is there any way to find out?
03-24-2011, 12:10 PM   #2
there's at least one thread from today that asks the same thing.
Search the forums.
03-24-2011, 12:24 PM   #3
QuoteOriginally posted by qtopplings Quote
Search the forums.
Oops! Sorry about that.
I've tried exiftool, etc. but to no luck--I want the manufacture date!
03-24-2011, 01:19 PM - 1 Like   #4
boriscleto's Avatar
To get a ManufactureDate type
user% exiftool -ManufactureDate /path/to/file
Make sure you use an original file.
A list of Pentax specific tags is here
Pentax Tags
03-24-2011, 03:23 PM   #5
QuoteOriginally posted by boriscleto Quote
Pentax Tags
Didn't work for me...
I typed:
which returned nothing, so I typed user% in front but that didn't work either.
Then I put my user name in for the user% but that didn't work either.
Hmmm... I do okay on terminal work in Linux but I guess I must not be nearly as savvy in OS X Terminal.
03-24-2011, 03:34 PM   #6
Oh yeah! Got it.
I always shoot RAW so I was converting the Raw image to Jpeg, and that's why I wasn't getting anything.
So I shot a jpg in camera and tada! worked perfectly!
Boriscleto, rep for you for your help!
03-24-2011, 06:06 PM   #7
ugh. I don't know anything about using the terminal and I had to use the droplet things to get the shuttercount (which was 3, fyi). I can't find the manufacture date on the droplet. What am I doing wrong?
03-24-2011, 06:13 PM   #8
Here is the URL of a website, where you can simply upload an image file, and it will display your EXIF data. I found my manufacture date here:
Jeffrey's Exif viewer
03-24-2011, 06:15 PM   #9
boriscleto's Avatar
QuoteOriginally posted by Allison Quote
It would be harder to explain how to edit the script than to explain how to use the Terminal. Here goes.
1. Open the Terminal.
2. At the prompt, type exiftool -ManufactureDate followed by a space.
3. Drag the file you want read onto the Terminal window. This will fill in the path for you.
4. Hit return.
To get a ShutterCount just type -ShutterCount instead of -ManufactureDate or you can get both by typing both.
03-24-2011, 06:25 PM   #10
4. Hit return.
To get a ShutterCount just type -ShutterCount instead of -ManufactureDate.
Got it. lot of stuff there. The website worked too and was kinda easier. Thanks!
03-25-2011, 08:34 PM   #11
You can drag the file into the terminal window to get the location/file name? Oh, very cool, I didn't know that! Will it work with a folder? One of the things I did with the K7 (when I had the green line) was to use exiftool to print the things I wanted to a tabbed .txt document (file name and temperature), but I sometimes had trouble typing the path correctly. Thanks for the tip, I'll have to try that.
05-16-2011, 07:50 AM   #12
would it be possible to create a service with automator. so that by clicking right on a picture, in the dropdown list, we could see all theses EXIF data displayed by photome? or at least the most usefull of them such as shuttercount?
05-16-2011, 10:18 AM   #13
QuoteOriginally posted by mtngal Quote
Yes, it works with folders. You can also find several online context-menu addons that let you right click and "open Terminal here".
05-16-2011, 12:10 PM   #14
boriscleto's Avatar
QuoteOriginally posted by oliver939 Quote
Just modify one of the the droplet scripts. For example change set exiftool_args from -S to -shuttercount.
Code:
on open the_files
set exiftool_path to "/usr/bin/"
set exiftool_args to "-shuttercount"
repeat with the_file in the_files
set exiftool_args to exiftool_args & " " & quote & POSIX path of the_file & quote
end repeat
set the_md to do shell script exiftool_path & "exiftool " & exiftool_args
display dialog "ExifTool Metadata:" & return & return & the_md
end open
http://owl.phy.queensu.ca/~phil/exiftool/List_Exif_Metadata.sit
camera, dslr, k-5, k-5 ii, k-5 iis, k5, mac, pentax k-5
Is there a program like/equivalent to PHOTOME for Mac OS X ? brosen Digital Processing, Software, and Printing 16 07-21-2011 11:55 AM
PhotoME shutter count 230 on 'new' K-7 Markah1 Troubleshooting and Beginner Help 13 09-16-2009 12:17 PM
PhotoME help NaClH2O Digital Processing, Software, and Printing 2 07-27-2009 06:42 PM
Photome - whats up ? Squier Digital Processing, Software, and Printing 10 04-25-2009 02:13 AM
K10D photo series - mac / aperture / .mac Tom M Photographic Technique 7 12-29-2007 03:13 PM
All times are GMT -7. The time now is 02:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
